*** The Official Diablo III Thread ***
Status
Not open for further replies.
Tom, I really don't think this is a problem with Blizzard, your the only person I have seen having any stuttering issues.. Was absolutely fine for me last night and this morning, and everyone elses seems to be ok?
My C.E finally landed !! shame that characters created on the guest pass don't get the C.E goodies :( (unless theres a way I don't know about).
Create a new char, put CE items in your stash, log onto previously created char, collect goodies from stash. Delete other char you used to get goodies. Rinse, repeat :)
What ping do you have in-game? Random question, but have you checked to make sure you're not on the Americas server?
About 200-300MS. My region selection in settings says Europe.
I had this the first night also. Are you using AMD drivers? If you updated to 12.4 (I think) there is a new 12.4a edition out to fix issues with some games, which fixed the stutter for me. Haven't had any problems since. There is actually a sticky on the official Diablo technical support forums with a direct link to the drivers. Think the sticky is called something along the lines of 'solutions to common problems' or something (cant check as I'm at work)
The 12.4a drivers aren't for my card though, they only fix issues for a certain series of cards. Mines a 5850 which no listed fixes.
Lol... I guess you haven't looked at the Diablo forums then. :eek:
A few other people from here are having the same issue as me aswell.
In the middle of university exams atm so I haven't bought Diablo 3, but I really want to play! Will either be a Monk or a Barbarian to start out with. Monk looks fun but Barb seems like more of a solid choice.
Anyone have a guest pass that they won't be using I'd really appreciate it.
That seems quite high, mine is always under 100!
Yup, in other games my MS is much lower. Stuttering doesn't happen after midnight as said.
im also using a 5850 and have not had stuttering once.
have you tried reinstalling the driver?
I've even formatted. Tried EVERYTHING. Their is a 25 page thread on the Diablo forums of people having the same issue and they have much beefier PC's than mine.
I'm still saying it's something server side as when it gets late I can play without issue!
Ping seems very high to me, have you tried running a traceroute to the servers, if their IP's are available? Might be something in the connection causing the problem, which calms down once the servers are quieter. Probably being routed via outer mongolia or something.
I'm having the load asset problem now aswell, when ever a new event loads i.e new sound, new mob spawning, I get a split second lag spike which hadn't been happening before.
Apparently these problems existed in the BETA which Blizzard said they'd fixed in the retail release.
If it was server side then everyone would be getting the issue.
I've never had the stuttering, even when its been a struggle to get online.
Its clearly your PC config/ISP Network Config and the client arent getting along.
Which ISP are you with?
does anyone know if there is a live dps meter in game?
my char screen says im doing 221 damage but i assume that is just my left click attack. would be good to know what im putting out in fights.
http://cloud.steampowered.com/ugc/578956500885007570/C7D46E620C26841090DD16389FB83AD9969E216F/
Short of the damage numbers not really. But you should hopefully be able to work that out.
My current dps is 493 (with an attack rate of 1.82) so in theory I should be able to get approx 750 dps from Disintegrate and that seems to be reasonably accurate when it ticks for about 400.
Bit dissapointed with co-op and pugs (Random groups). It's more like a race around than actual co-op. Might change as the difficulty levels up, but I'm sticking playing with friends.
Does that ever go any other way? Particularly with 'easy' content? Its too easy to just waltz off and solo stuff when you're playing public.
Marvelous !! cheers for that, for some reason I thought they were character bound.
Can also confirm this works, I had a little rage to myself about this yesterday, thought I'd give it ago and all items are account bound :)
Those of you who are witch doctors, what spells/combos are you mainly using?
I'm using this build: http://eu.battle.net/d3/en/calculator/witch-doctor#aZSjYT!dWe!aZaabZ
Darts: single tagert/low mana skill, Pets: support, Locust swarm and grasp: "aoe" damage, slow down, Mass Confusion: "oh ****" button, works great when you have too many packs of elites etc.
I chose Pierce the Veil passive as this is a relatively low mana cost builld, and therefore the 20% damage boost from it is very effective.
Locust swarm is the real key here, it can spread exponentially given enough mobs. Any strays can be easily killed with darts/pets.
Status
