- 22 Nov 2007
- Ayr, Scotland
Nice to know, will try CCC to start with but have Asus GPU Tweak (3 versions) downloaded ready to try, reading through this thread at the moment.
So I tried my hand at overclocking my XFX 7850. Core: 1200, Memory: 1450. Sadly I need to bump up my voltage in order to obtain that.
Dunno if that's a good OC really.
Asus website has them, That is where I got my version from.
http://support.asus.com/download.aspx?p=9&m=GPU+Tweak&hashedid=n/a
Edit: Make sure you download from the global download link.
go into settings and in the tuning section put a tick in the "overclocking range enhancement", that should increase your overclocking range.Cheers, got 2.0.8.3, and whilst it now lets me adjust the voltage, I still can't up my clocks beyond 1050 as that is the max of the slider.![]()
Whatd you do to be able to adjust the voltage of the XFX card? I, as well as some others, haven't been able to do so. Are you using Asus Gpu Tweak? If so what version?
That's what I did, which allowed me to mess around with voltage, but the GPU and RAM sliders still max out at the same as CCC.![]()
Don't think there is a way to increase the limits in ccc?
I mean that in GPU Tweak the slider still maxes out at 1050 (the same that CCC maxes at).
Trying to use this software but I dont see an option in settings\tuning for 'overclocking range enhancement' using ver 2.8.3 and wont go beyond 1050mhz.![]()
And Trixx will work with my VTX?
