Warm isn't it? Want a hydro cooler at a great price? Over £20 off!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
Corsair buy this cooler from a company and then add two fans and a Corsair logo and and a printed Corsair printed Box.
OcUK have also bought the same cooler, and left it as it is and we sell it at an amazingly great price - all you need do is add your own fans and away you go.
This warm weather can cause your CPU to operate above ideal conditions, heat wise, so this cooler with fight against that heat and give you better temps.
OcUK H²Flo Extreme Liquid Dual Fan CPU Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £43.98 inc VAT
The OcUK H²Flo EXTREME Liquid CPU Cooler is a fantastic product aimed at high end CPU cooling, with the power to slay any overclocked CPU temperatures succesfully. The cooler houses a large surface cold copper plate to ensure all the heat is drawn away from your CPU and transferred to the sealed liquid and the pump then transports the liquid round to the dual thick radiator which then cools the liquid back down to enable the liquid to recirculate back to your CPU block to again pull more heat away. All you need to do it add a fan of your choice to the radiator and your CPU will be cooler than the next Ice Age.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 38mm
- Fan Support: 120mm x 38mm x 2
- Double-thick 120mm radiator for increased surface area and cooling potential
- A new improved micro-channel cold-plate design more efficiently transfers heat
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Cold Plate: Copper
- Radiator Material: Aluminium
- Thermal paste is pre-applied
Was £64.99 Inc. VAT
Only £43.98 inc VAT.
ORDER NOW
chillisteak (Wales) said:
Now I'm well happy with this, it came bundled with the system purchased (didn't realise) so when I noticed it I was shocked and curious all at the same time. so far highest temps I've seen on the CPU is 21c that was during gaming, on average temps hover around the 9c mark. lowest temps I've ever had on a system!
lol? :confused:
any proper reviews on this?
So would I!
They are on order and due this week. Get your pre orders in now if you want one because 90% of our allocation is taken up by pre orders
Woo! :D
I'm tempted by one of these coolers, and i'd snap one up if I hadn't blown all my computer money on nickel plexi and D5's :(
Ooh, very tempted by this!
I currently have a Thermalright IFX-14 which is getting on a bit now, so a new cooler would be nice, but how much of an improvement would it be?
Also, any idea how long the price will be so low, so I know how long I have to consider it! :D
Edit: Just seen its on TWO! A week, perfect!
lol? :confused:
To be fair the sensors on most CPUs aren't very accurate below 25C or so - I've often seen ~12C CPU temps at idle when using high end air/watercooling when obviously without phase, etc. its not going to drop below the ambient best case.
