- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
Corsair buy this cooler from a company and then add two fans and a Corsair logo and and a printed Corsair printed Box.
OcUK have also bought the same cooler, and left it as it is and we sell it at an amazingly great price - all you need do is add your own fans and away you go.
This warm weather can cause your CPU to operate above ideal conditions, heat wise, so this cooler with fight against that heat and give you better temps.
OcUK H²Flo Extreme Liquid Dual Fan CPU Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £43.98 inc VAT
The OcUK H²Flo EXTREME Liquid CPU Cooler is a fantastic product aimed at high end CPU cooling, with the power to slay any overclocked CPU temperatures succesfully. The cooler houses a large surface cold copper plate to ensure all the heat is drawn away from your CPU and transferred to the sealed liquid and the pump then transports the liquid round to the dual thick radiator which then cools the liquid back down to enable the liquid to recirculate back to your CPU block to again pull more heat away. All you need to do it add a fan of your choice to the radiator and your CPU will be cooler than the next Ice Age.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 38mm
- Fan Support: 120mm x 38mm x 2
- Double-thick 120mm radiator for increased surface area and cooling potential
- A new improved micro-channel cold-plate design more efficiently transfers heat
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Cold Plate: Copper
- Radiator Material: Aluminium
- Thermal paste is pre-applied
Was £64.99 Inc. VAT
Only £43.98 inc VAT.
ORDER NOW
Was £64.99 Inc. VAT
ORDER NOW
