Vodoo OTA Rootkeeper to temp unroot and disable SuperUser (Easy if using SuperSU).
Thanks downloaded and done, ultra easy!
Done, and it doesn't work, when I choose a channel to watch it just gets stuck on loading![]()
They always take ages on the loading, you have to hide root as Intratech showed, you also need a Sky id and password for it work.
Hmm, I originally ordered a blue from Amazon a few weeks back but cancelled and changed to a white earlier this week. The delivery went from 30th May to 8th June so either they didn't have any stock or I was back of the queue.
Have just checked and it is now estimated for delivery tomorrow and despatching soon! Anyone else have theirs change with Amazon?
Edit.....actually it is working, it's virgin that's being a ***
So it works? Displays the video feed properly??? If so ...BOOYAH!!![]()
Anyone have lag when watching embedded flash videos? Mine Is pretty bad and was wondering if there was a fix?
Have you updated flash player via the Play Store?
Hi mate, i did a test against the htc one x, i played the desktop bbc iplayer selecting the HD versions , HTC one x is perfect while the s3 lags,
s3 works fine on normal quality sd on desktop bbc iplayer, but not as good quality as the hd versions
To all CPW orders with free Tab's, i need some help
Now i was one of the lucky ones(well unless i get screwed) to be part of the first 1000 orders, and because i decided to stick with blue s3 i'm still waiting of course.
For those with white s3's and choose collect at store, did u
a) get tab whilst collecting s3
or
b) are still waiting for tab, as a seperate parcel delivered to home address before 5th june?
Now i'm guessing that those who did NOT choose collect from store option are waiting/have received there parcel.
K
I ask this because i'm getting hell loads of different answers from CPW staff in store, CPW staff on phone and looking at this post qouted above.
nrenz123 i'm guessing looking at your post you collected the whole lot from CPW store?
Which is contrary to what i'm been told (half the time), btw i also did collect from store option.
i guess i'm being paranoid but i don't want to collect my blue s3 (could be a while i know!) without tab, then wait for parcel with tab that never arrives, which then leaves me with no tab becuase CPW said i didn't collect it from store so they say you lose out.
i think u get my drift...
