- 12 Jun 2006
Is it better (and cheaper?) to stack a certain res instead of all res and use the buff which makes all res as high as your highest amount?
Not sure it's actually that impressive. Key things missing... No NV on quite a few of them, and you can see on quite a few bosses he's running so he doesn't get owned... His Ego is too big.
for monk, if you can, stack all res + a single res (eg, poison) and use the one with everything passive. single res affix nearly gets same max stat per item as all res, so you can get nearly double res if you can afford itIs it better (and cheaper?) to stack a certain res instead of all res and use the buff which makes all res as high as your highest amount?
for monk, if you can, stack all res + a single res (eg, poison) and use the one with everything passive. single res affix nearly gets same max stat per item as all res, so you can get nearly double res if you can afford it![]()
Aye, the only problem is it can cost you a lot more as you'll probably have to pay over the odds to get an item with both good stats and the specific res you want.
Anything with good stats and all res is probably going to be costly anyway. Good stats + all res + single res usually isn't a huge deal more expensive, obviously rarer though.
Edit - anyone put a price on this
I mean that since you're looking for one specific res you might have to pay more just to get hold of it as you're limiting yourself to one specific type which is going to give you much less choice.
what do people mean by stacks of 5 Nephilim? Do you teleport to all the different zones picking up +25% find magic items then go do a boss?
im feeling as though the game is flawed - done act 1 inferno a ton of times and the gear that drops just isnt enough to do act 2, most of the weapons are sub 500 dps, and the armour is nothing to write home about either.
Im feeling forced to use the auction house, and my game time is all about gold farming now as the gear to do act 2 is very costly.
For me, this has taken a fair bit of fun out the game as im not excited about loot now, as i cant remember the last time i have found anything usable.
Played over 200 hours so its not like im doing 30 minutes here and there..
still, worth the £40 for the amount of playtime i have had, but struggling to keep motivated to carry on
You get one stack of Nephalem Valor per rare pack you kill, +15% MF / GF per stack. Get 5 stacks then kill a boss and rinse/repeat or keep killing rare packs.
