- 14 Feb 2008
- Cheshire
Thanks very much 5UB, code received and CS:GO is downloading now, thanks again!!
I need to receive an email from the person who posted the image so I can pass the code.
Below your post where it says "Edit" click on "Trust" next to it and set it up.
Once it is set up, click on "Trust" on my post, and you will be able to send me an email so I can reply and send you a key.![]()
when I click "Trust", it pop-up new small window and there is 2 button : "find" and "login". I don't know what to do with "find" but, when I click login and put my username and password - then it says I don't have permission![]()
anyway did I won the key?
How to set up trust
You see the 'USERS TRUST' button on the bottom right of each of your posts? Press it. Put in e-mail and stuff, and you are good to go.
How do you sent 5UB a trust
You see the 'USERS TRUST' button on the bottom right of 5UB's posts? Press it. Click 'Send a Message' and compose your message.
How do I link a post
You see the number on the top right of your post? Well, click on that number (on the one where you have the image posted) and it will open in a new window. Send the link of that post to 5UB.
In order for other people to access your server, you must open port 27015 (UDP/TCP) in your router, to have it forwarded to your computer. This is different for each router model, but will generally be listed in the router control panel as "port forwarding". The port (27015) needs to be forwarded to your computers internal IP, which can be found in the router control panel's devices list, or in windows command prompt with the command "ipconfig" (usually your router will have the IP 192.168.x.1, and your computer will be 192.168.x.y)
The server IP will be IP:27015 where IP is your public internet IP, which you can find at http://ipchicken.com/
From the main menu, play -> create match -> chose competitive -> click de_dust2
Then, in console, set: mp_autokick 0;mp_freezetime 10;mp_force_pick_time 0;mp_limitteams 0;mp_startmoney 800;sv_deadtalk 0;bot_quota 0;
Once you're ready to go you simply enter the following to lo3:
mp_restartgame 1
mp_restartgame 1
mp_restartgame 3
say LIVE LIVE LIVE
This can all be put in aliases in your config, e.g.:
alias "match" "mp_autokick 0;mp_freezetime 10;mp_force_pick_time 0;mp_limitteams 0;mp_startmoney 800;sv_deadtalk 0;bot_quota 0;" alias "warmup" "mp_freezetime 1; mp_startmoney 16000; mp_restartgame 1;"
alias "lo3" "mp_freezetime 10; mp_startmoney 800;" // only needed to undo warmup settings alias "rr" "mp_restartgame 1" alias "rr3" "mp_restartgame 3" alias "live" "say LIVE LIVE LIVE"
Bugs:
- If you set a server password, anyone trying to join (even with correct password) will crash. If you want to prevent people from joining, set sv_password "whatever" after all 10 players are in, then remove it with sv_password "" if anyone needs to rejoin.
- If you change the map (changelevel de_dust2) then all players connected to your server will load into their own local servers on this new map, and will have to quit their server, then reconnect to your server
- If the server host tabs in/out of game, the server will lag badly
- When you create a server, all server settings are reset (e.g. freezetime, autokick... etc) hence needing an alias to run them every time you create a server
It's worth noting that at half time the teams auto-swap and scores keep going, so there's no need to lo3 at half time. When one team reaches 16 rounds, the game is over. Sourcetv commands are built into the game, except tv_enable, meaning SourceTV is not available to use at the moment.
Sent you a message, did you get it? If so reply to my email address manually (don't auto reply as it will come from a noreply at overclockers.co.uk address. Send me the link to your image here.![]()
