The only file you need from the enbseries_skyrim_v0113.zip is the d3d9.dll from wrapper folder, put that in the Skyrim folder (folder with TESV.exe in it). Then search Nexus for ENB, sort the search by downloads or endorsements to get the popular ones. Download one, extract it, put the files in Skyrim folder with that d3d9.dll.
enbbloom.fx"
enbeffect.fx"
enbeffectprepass.fx"
enbpalette.bmp"
enbseries.ini"
d3d9.dll"
Those are the 6 main ENB files, some presets have more.
enbbloom.fx"
enbeffect.fx"
enbpalette.bmp"
enbseries.ini"
d3d9.dll"
