I cant disclose which manufacturers use which IC's. I have been specifically asked this by the manufacturer them selves.
G.Skill then?
NO!!!! GSKill TridentX 2666mhz I have are not Samsung.
After googling about, it would seem the 1.62v is perfectly fine, a lot of people run 1.65v with SB-E
Patriot then?
Take off some heatspreaders at OCUK!!!!![]()
I see what you're doing there....
there only 30nm,they DONT get hot
stick on heatspreaders would aid installing/uninstalling the ram module though
They do when u push them.
I've tried just about every combination and I can't Overclock my 8gb set at all. No errors in 6 hrs in Memtest at stock 1600mhz 11-11-11-28 1.35v, but as soon as I change timings or frequency and up voltage memtest gives me errors. Couldn't even get CL11 2133mhz at 1.6v through memtest without errors. Have I been unlucky and got poor overclocking sticks or could it be my motherboard? Notice you guys with the Maximus V Gene have had awesome clocks! Anyone had a good OC on a Gigabyte z77 with the Samsung sticks?
