****Show Us The inside of your Case!****
Another addition.. nearly finished with its looks!!
Was happy this morning my bitfenix 6 pin red came from america only to open
it up and find they had sent me a 24 pin connector!! :'(!!
Macarule, how are the noiseblockers noise wise? How much air do they push?
they are excellent, on full all you can hear is air noise, when down at 50% practically silent and they push a lot of air :)
switched out my tubing and added new lighting, 6Pin extensions are on their way!
http://i900.photobucket.com/albums/ac203/macarule/RIMG1110-2.jp[/QUOTE]
Do those graphics cards get hot?
I am only saying because there is little gap between them.
Mmmmmmmmmmm, nice :cool: may get some of the noiseblockers when I upgrade my case :)
Thanks, I Love 'em, one of the best fans IMO...
yeah they do haha, top card gets to the high 80s in 3D Mark :eek:
Looking awesome macarule!
Thanks MastyLR :D
Interesting place to mount 5 1/4 fan controller. Zip ties?
i needed a place to mount it... good old zip ties ;)
Just tested using ur screen, doesn't work for me either, odd.
Anyway, looks nice man, you dont need fancy cable management :D
Nearly finished with this :D
Just waiting on..
6pin red bitfenix cable.
two 120mm Corsair AF120 for the push pull
And finally treated myself to come Corsair Dominator GT ram 8GB
Fully lights up red inside now too thanks to two pairs of bitfenix LED strips but i'll get better pictures and show you when its all together :D
Are you using different fins for the dominators?
EDIT: Nvm, didnt realize you've only just ordered them
Custom paint job by myself, and I've now re-sleeved the 24pin power cable so the coloured cables aren't showing like in the picture. Also ive added grommets which aren't in the picture either. Will take another one when I install my n520 cooler (need to buy a mounting bracket for LGA1155)
