Essential Android Apps
Status
Not open for further replies.
How are people finding the quality of the feeds through SkyGo? I've got it working on my S3, but the picture quality is dire, much worse than all other streams, and pretty impossible to make out any details.
Is this normal, or are there any settings that I've missed to up the quality?
When I was using it the first load was always blocky so I'd press back & reload it & everything would then be perfect. Haven't used it for a while though!
I left it to play for a while and it seems a lot better now, looks like it was just setting itself up. Crisis averted!
Anyone used the VGBA emulator? Or know of any better Emulator for the GBA?
I installed Gameboid today, seems good so far. I don't think its on play.Google but can be downloaded if you search for it in Google. Iv been playing pokemon Leaf Green on and off. :p
Surprising thing about it, it don't seem drain the battery that much which is a plus!
If anyone uses Spotify then their beta app is much better than the one on the market - see here.
Also, what browsers are people currently using? Have been using chrome but the bugs in it make it so annoying to use, also tried Dolphin HD but I can't get used to the interface.
HSBC Fast Balance
Camper (use this for work)
MediaDog
HotUkDeals
PAC-CHOMP!
Rom Manager
Unified Remote
Cyanogen 9 Nighties (Samsung S2)
Those are my daily use ones.
Using Chrome here - The bookmarks being synced from my desktop is too good to give up!
Status
