anyone tried Windows 8 Release Preview on this board ? won't install on my Gene V Z![]()
^^ nope - although my 480 - is only 2 slot not 3
but it is very long - 300mm and I've had no issue
http://forums.overclockers.co.uk/showthread.php?p=22859094#post22859094Only problem with the Windforce 7870 is that it doesn't fit onto an Asus Maimus V Gene motherboard due to the graphics cards extended heatsink hitting the SATA ports. I had to take a dremel to one corner of the heatsink, so it's just as well the card worked. The Windforce X3 is a great cooler for this card, perhaps being overkill for such an effficient GPU.
