Wow I can't believe that Rainforest are selling the HTC One S for £377.49. Quite literally pound for pound that's a bargain. IMHO aside from the S3 the HTC One S is one of the best android phones on the market and the S4 chip is what the UK version of the One X should've had.
I also like to add that I haven't had any chipping issue with my HTC One S and it's as good a new even though it's one of the older versions that was released and not the new version that's out.
Just under £400 doesn't strike me as being that cheap...?
HOX with S4That would literally be a dream! Would have been good to have that version as well. Best of both phones in one, SLCD2 along with S4.
That could quite easily have the S3 beaten for everything bar storage IMO.
Just another ridiculous decision from HTC.
afaik - Tegra 3 SoC is cheaper to buy than the S4. And the S4 supply is tight.
@Nexus18 My USB port area isn't showing any wear and tear around the edges, there's only slight wear (grooves) inside the USB port but other than that it's ok.
What about your USB port?
Yes I was lucky however I had to go through 4 HTC One S which all exhibited the chipping problem before I struck lucky with this one Mate.
I've used the official HTC leather pouch for my phone however I got bored of taking the phone out of the pouch when I had to use it. In the end I settled for a TPU case from ebay which has done the job nicely.
However Nillkin are high quality cases and you've done well to get that brand as that will protect the HTC One S nicely!
I'd like to hear your thoughts on the case when you get it delivered.
The one S is finally getting more popular now! About time as well!![]()
At least you got a good one in the end then, eventually!
Did you return it to where you bought it from or via HTC directly each time?
Was looking at pouch cases myself as well when I just got the S, but too much faff is required plus I would be more likely drop the mobile taking it out of the pouch and putting it back in![]()
Yeah, love the look of the nillkin, they are my ideal cases, just wish they covered the top and bottom a bit more though
Will be posting a full review of it not long after I receive the case
Although it could be a bit longer till I actually receive the case as I think it is being shipped from China so![]()
I look forward to hearing what you think of the S when you get your hands on them!![]()
The first two were ordered from Rainforest so I had no hassle returning each of them and getting a refund. CPW were my next stop and when that phone turned out to have the chipping problem they offered me an exchange / refund straight away. I took a refund and waited for 3 weeks hoping that a new batch of HTC One S's would be released.
I placed an order from Handtec who assured me that none of their HTC One S batches had been affected and if I was to come across the chipping problem then they would offer an exchange / refund, thankfully this HTC One S turned out to be fine.
You can get the Nillkin TGP case instead which covers the top and bottom instead of the Niilkin slim case, yes it adds a little more bulk but at least you've got the whole phone covered.
I ordered my TGP case from this seller on ebay and I've ordered 5-6 cases from them and they're very good.
http://www.ebay.co.uk/itm/170827620...X:IT&_trksid=p3984.m1439.l2649#ht_1928wt_1139
Same as before I imagine
+ Cracking design, materials, build, battery life and speed.
- No storage space, grainy screen and questionable software choices (multi tasking and software menu key etc)
My contract is up for renewal next month so £14.50pm for unlimited data, 200 mins and a free One S (without redemption faff) is too good to pass up.
#inbeforeS3
