Suspended
- 17 Oct 2011
- Buckingamshire
Cool, i do some of that on my ride, Henley, Marlow, Bourne End, Maidenhead, i start from Bracknell side tho
[DOD]Asprilla;22114257 said:Knee pain could be any number of things, most likely cleat positioning.
Back pain sounds like a result of the frame being too small. Raising the saddle makes your bum higher but increases the drop between saddle and handlebars. You've put on a longer stem to take into account the short top tube but unless it's got a massive degree of rise on it you are still going to be bending over a long way. I would suggest your problem is a short head tube on the small frame.
If it's any consolation I did exactly the same and bought a frame that was too short and had the same issues.
Get a bike fit. Most shops will discount it from the cost of whatever you buy as a result of it.
Lead Head, I'd pay for a proper bike fit. There's too many variables to get it right by yourself if you are inexperienced. Although the lower back pain could be caused by a longer stem, it can also be caused by a frame that's too big, or a lack of flexibility and core strength.
Anyone doing Bristol Biggest Bike Ride this Sunday?
Brush off anything loose or if it's caked in mud give it a sponge down with a bucket of water and a bit of car shampoo. Then clean the frame up with an oily rag. I run the chain through a rag by winding the cranks round to get the most of the built-up crud off it but never bother taking it off and soaking it. I sometimes spray it with WD40 to loosen any thick gunk, same for the chain ring. If I've got the wheel off I'll take the cassette off, separate the gears and clean them all, but this might only be once a year or less.ok, bike cleaning time
what do you guys use/do when cleaning your bike after it's gotten filthy riding to work in the rain?
not got a chain cleaning box or anything yet so it's sponges and brushes only right now!
No, it doesn't.Somebody will post this said:I'll never use WD40, it has silicone in it
No, it doesn't.
I'd tend to agree with poor core strength. Is there a way to test core strength?
Over 70 miles of hills in the Peak District on Sunday, my legs are destroyed.![]()
Unsurprisingly! Well done!![]()
Certainly made a change to the south-east, Highgate West Hill and Box Hill will never look the same again! Always nice as well when an event billed at 100km clocks in at just a "little" over that distance - maybe the 100km referred to the vertical part of the course.
I've had a bike fit last Tuesday, who suggested the longer stem to make the bike fit. I agree now the seat has been raised I'm leaning over a lot further coupled with my poor flexibility isn't helping.
I bought the bike from one of my friends who I ride with, I'd feel guilty chopping it in and buying a different bike as he did me a good deal 6+ months ago.
[DOD]Asprilla;22119064 said:I had the same but they were also frank about the fact that the new stem and seat position was a case of polishing a poo. Yes, the reach was right and yes the saddle was right but the drop between saddle and bars was around 6".
It was very areo and quick; the following week I finished quickest in a 70 mile Dorset CTC sportive but I could barely walk after getting off the bike.
I'm having similar issues - what was the solution for you? I appreciate these are all very personal but it gives me a start on what to look for in a new bike.
