Exceptional!
But you forgot to mention other details like screen brightness and if smart stay (eye tracking) was turned on, phone calls, texts, what is syncing etc.!?!?!?!?!
So far gman and mrks usage are the only ones that I have been impressed with.
Dude ignore that! Like I said he's just copy and pasting from elsewhere. There is no need to wipe anything or take battery outInstructions For Flashing Firmware:
Extract the firmware
Open the included Odin
Put your device in Recovery MODE (Home + Volume up + Power)
Wipe Data/Factory reset
Wipe Cache
Take Out Your battery & put it back in
Put your device into Download MODE (Home + Volume Down + Power)
Click PDA and select *.tar.md5
Then finally click START!
Does that delete everything ?
Best to backup with titanium pro ?
Exceptional!
Brightness is on auto, no haptic, turned off Smart Stay about half way through (doesn't seem to do much tbh) syncing Facebook/Twitter/Gmail/Dropbox, phonecalls (not long though) and texts.![]()
Damn
Just placed an order with Three on The One Plan and I appear to have failed a credit check, Got an email saying.
"Thanks for your recent order with us. Before we can send your order we need to confirm a few details with you."
Someone is going to call me soon, I waited and waited, no call so I called them and guess what? Closed
My credit score is great! no problems whatsoever. This is the very first time this as ever happened to me, is it a Three problem?
Do you need to be impressed for it to be validated?![]()
To those who have recieved the Pebble Blue in the last couple of days... does the new "Metallic Blue" colouring fit with the "it actually look like gunmetal grey" descriptions posted around the interwebs?
So many conflicting opinions about it!
Happened to be as well, They called just to confirm a few details and then they processed the order !
Cheers
Good to know I'm not on my own then, Just hope the Pebble Blue is still in stock by the time they get round to calling me.
Was hoping to order the wife one as well!!!
Cheers
. What resolution should I be looking for for wallpapers for the S3?
1280 x 720 I think.. funnily enough I was just looking for some myself, post em if you find some good ones!
