***The Official Samsung Galaxy S III Thread***
The whole site is on the dockyard side yeah. Nice views all round. Office isn't on a ferry though, I commute by private boat and passenger ferry.
Alarms: On the Desire you could tap the clock widget and it'd take you into the clock app, on here I seem to get taken into the clock settings so I have to find the clock app from the app drawer.
This really annoys me. I've had to download and install a different clock widget that I won't even like just so that it jumps to my alarms when I click it.
Agreed. It should go to the alarm/stopwatch section when you click on the clock widget and not the settings. All they had to do was get you to press the menu button to enter the settings when in the aforementioned screen... Quite annoying :(
I am looking to find an sd card for my phone and am looking at this one on the rainforest
Samsung MB-MSBGAEU 32GB Class 10 Micro SD
The reviews say they have bought it for the S3 but I just wanted to double check that it is compatible.
Any of these SD cards are compatible. As long as it's micro sdxc/sdhc it will work unless it's a fake or is doa.
I'm finding auto brightness works well on Siyah Kernel so I think I'll leave auto enabled when using this kernel. It's updated to 1.0.1 btw.
I just use the default alarm widget alows you to scroll through your alarms and activate or change them. simple.
I cancelled my play.com order for the blue. I spoke to Amazon and they said they will be getting enough stock tomorrow to fulfill my order if I place it now so I did, supposed to arrive on Monday. Hopefully Amazon are trustworthy, we'll see!
Greebo I've been using the alarm on my ICS S2 every day for a long time and haven't had any problems, that's with the stock clock app.
Just finished customising my S3 to my usual tastes... dark and relatively clean theme. :)
Will probably have to do it all over again when I do Omega 5.0 this week but hey ho, kept me busy. :p
what theme are you using or Launcher please? (couldn’t add the photo for some reason)
How you backup your old kernel ?
