http://robbiekhan.co.uk/root/android/20120615_083435.jpg
View from the office using built in pano mode, nice!
Looks like your office is on a ferry or the dockside.
Alarms: On the Desire you could tap the clock widget and it'd take you into the clock app, on here I seem to get taken into the clock settings so I have to find the clock app from the app drawer.
I'm after a blue one sim free, does anyone know of any availability?
Cheers![]()
This pretty old HTC clock widget allows you to configure what happens when you press on it, you could make one side of it a shortcut to the clock app and it would probably suffice - http://dl.dropbox.com/u/1690737/com.ermesjo.yr.apkClock woes![]()
LolStockAlarm, I use Kaloer Clock as it has a brilliant dock mode.
http://www.ur-mobile.com/vm/samsung...y-s3-iii-sim-free-unlocked-mobile-pebble-blueI'm after a blue one sim free, does anyone know of any availability?
Cheers![]()
This really annoys me. I've had to download and install a different clock widget that I won't even like just so that it jumps to my alarms when I click it.
Got my S3 today, Sim free. How do i remove bloatware
Just finished customising my S3 to my usual tastes... dark and relatively clean theme.
Will probably have to do it all over again when I do Omega 5.0 this week but hey ho, kept me busy.![]()
I would also like to know this.
Will I need to root the phone to remove the apps I don't want?
Any of these SD cards are compatible. As long as it's micro sdxc/sdhc it will work unless it's a fake or is doa.
I'm finding auto brightness works well on Siyah Kernel so I think I'll leave auto enabled when using this kernel. It's updated to 1.0.1 btw.
