- 16 May 2008
- Bristol
Am I a bad person for running 2 sticks of this stuff at stock?
Am I a bad person for running 2 sticks of this stuff at stock?![]()
more experimentation
2200 10-10-10-24 1T seems fine and stable @ 1.55V
CAS9 at 2200 at voltages (sub 1.57) that I am happy with seems a no go - as does 2400
so anything else I can tighten up on current settings please ?
People tend to run it for 24 hours to be 100% sure, but I just run it for the duration I'm at work, 10-12 hours etc.how many passes of memtest would be classed as stable?
is there any of this ram X58 compatible?
Seems quite excessive really, I'd personally run it for less and then do some Prime95 Blend / LinX All Memory from within Windows.
Better safe than sorry, I had some RAM error on me after 7+ hours....Seems quite excessive really, I'd personally run it for less and then do some Prime95 Blend / LinX All Memory from within Windows.
Just passed memtest @ 1866mhz 9-9-9-27 1T for 10+ hours, 10 passes.
Next I would like to try 2000mhz 9-10-10-28 but as I mentioned in an earlier post if I set bios to 2000mhz it reports it at 2669mhz in memtest.
Bit confused as to why?
Cheers fella, thought it had to be a bad reading, system defo wouldn't boot at 2669Mem test problem. Dont worry about that.
It what sense?
You can't buy it in packs of 3 so your choices are:
- Buy 2x 8Gb kits and sell 1x4Gb = 12gb of RAM
- Buy 3x 8Gb kits = 24Gb of RAM
