It really is a shame its doing this as I honestly think its a nicer phone than the One X, can't understand what's going on at HTC.
Not much as far as the One S is concerned. I too have not suffered the the helicopter prob thankfully.
I've acquired a Samsung GS2 second hand off the auction site. Got a bit fed up with poor signal issues and need a phone with a signal. What do I think of the S2? Not right keen after the One S but it does seem to have better mobile signal reception. Can be a bit funny in the house but mostly has 2 out of 4 bars where One S was 1 bar out of 5 and often 0 to disconnected. The Samsung does lose data occasionally in the house but remains connected to the 3 Network.
I've had a yearning for a look at a One X or Samsung GS3 so had a ride to town to look at working examples in the Three shop. Both had nice screens it had to be said, particularly the GS3. What I wasn't so keen on was the size. One S or GS2 are about as large as I really want to go. One S I could live with IF bl***y HTC
would sort the signal issue - not withstanding the miserly fixed 16GB
In town today the GS2 had no signal probs and even in one of our fave watering holes where the OneS struggles to hang onto reception, the GS2 had no probs. That said we went over to Liverpool last night and took the One S as the GS2 wasn't 'loaded' and had full signal everywhere? Top tip if you live in Liverpool
Other area where the GS2 isn't so good is battery - crikey can it munch through the battery! Probably needs tweaking and isn't on ICS yet (though that may not improve things?) so could be improved on. Being s/h the battery could be tired but at least you can change the battery. No storage shortage with the GS2 either unlike the One S where the 16gb total is a mistake I think and does put potential owners off - more so when they twig they only get around 9gb (or is it 10gb) for media etc.
Having got used to ICS on the One S going back to 2.3.6 on the GS2 is a bit of a step back. Touchwizz I don't like after Sense 4 but that is just my preference. I'll look into loading an ICS rom for the GS2
The One S should have been a winner but fear HTC have crippled it
very disappointing but I live in hope
Should there be an update or a fix for the signal issue then the GS2 will be gone in a flash
Maybe HTC will learn from this and do better next time????
