This the first time i have tried water cooling just thought i would have a go at it.
The specs are
1090t @4.2Ghz
Crosshair IV Formula Motherboard
GTX 590 With EK Block
8Gb Corsair Dominator GT 2133Mhz
Asus Xonar D2X
OCZ 850w Power Supply
For The Water cooling
XSPC raystorm D5 EX360 Kit
Phobya G-Changer 480 v1.2 Radiator
MIPS Full Motherboard block
EK 590 Block
XSPC High flex tubing
XSPC Compression Fittings, EK 90 and 45 degree angles
3x Akasa Viper fans for the 360 radiator, 8x XSPC 1650 rpm fans for 480 radiator
Temps are good CPU Idle 30 degrees core temp 21 degrees. Load temps are 55 and 40 degrees for the core at an overclock of 4.2Ghz
GPU Temps are Idle 26 degrees load 39 degrees on Bf3.
A few pics let me know what you think please......
http://s1050.photobucket.com/albums/s414/tpwilko/?action=view¤t=DSCF0643.jpg
http://s1050.photobucket.com/albums/s414/tpwilko/?action=view¤t=DSCF0650.jpg
The specs are
1090t @4.2Ghz
Asus Xonar D2X
EK 590 Block
I'd hate to try and move that but sweet temperatures. Though I'm puzzled how the graphics card is so much cooler than the CPU.
