So what happens if it starts raining a bit during a race? Red flag it for 2 hours to let everyone change setup, only for it to then dry up?
They could mandate a higher ride height, but they already manage the ride height with the plank, which sits below the reference plan. Whatever you do your still going to have a large plank only mm's above the road acting as a rudder.
Things may need to be looked at, but I think its more a case of people having to accept that 'Formula 1' as it is is a series that cannot run in heavy rain.
Well no, you raise the car, the plank would then be far higher than a few mm off the floor.
Depends which option they went for. Could just raise the car inn the rules, so even in dry races you have cms and they wouldn't have to stop. They could allow it down to the teams and as such it's upto them to predict the weather and if they don't raise the car tough luck, pull in or crash.
Or if they have to declare it wet you could red flag and stop for 15mins and have some sort of mandatory fast system in place to raise car.
Or more than likely do nothing and just say its bad luck, despite having several wet races a year.
