Your still at stock right?
Why did i not think of an oven? I blowdried and cut the adhesive whilst on a vice![]()
Good job mateInteresting to see that a tidy up and relatively normal thermal compound makes a difference too!
How do you glue the lid back on once you remove the adhesive?
Here is my temps @ 4.7ghz instead of 4.4ghz using liquid pro which arrived today, I put it on the CPU chip itself but also wiped a lot off just make sure the heat spreader had very close contact with the silicon.
Put some between the water block and chip and again wiped a lot off, bare in mind that I only put a very small amount on as well, seems that just the tiniest amount goes a long way with this stuff.
I'm very very tempted to try this given that the poster above said he got a decent temperature improvement by changing it to some that isn't even the fabled liquid metal pro!
