Not completely sure what settings each relates to above as the games doesn't use a simple list format but I'm using the following DayZ/arma 2 settings.
Texture Detail - Very High (Because I can with 2GB)
Terrain Detail - Very High (Because I want to
Post Process - Low (sharper image and more fps/ so prefer low)
Video Memory - Default (this was it can use more than 1GB memory)
Object detail - Medium (big fps hit and only minor improvement going higher)
Interface Size - Very small or normal (apparently helps with compass degrees)
Anisotropic Filtering - High (good enough)
Shadow Detail - High (good enough / fps)
Aspect ratio - custom (16:10 1920x1200)
Antialiasing - High (good enough)
HDR Quality - High (good enough / fps)
I played around a bit initially but found the mentioned settings to provide a good mix quality/performance given my hardware
It took me ages writing out the above before realising we're on the screenshot thread and I could have just posted an image
