****** Official World of Tanks OcUK Clan ******
Quick bit of guidance please.
Currently in the PzKpfw IV which I have unlocked everything on and am now progressing nicely to my next t6 tank. My question is, which route would you take, VK 3601(H) or VK 3001(P)?
Thanks
Does the 3001 get the short 88? VK36 gets the front armour (if you're rich and into firing gold the konische gun), the 3001..... nothing. Can't look at tech tree at work so probably the tanks that unlocks the most options.
IIRC 3601 proceeds to tiger (H) and the 3001 to the tiger P? BTW Tiger P will be linked to ferdinand for ridiculus XP (~150k). Never played the 3001 though so I can't comment. Neither the maus or E-100 is used much in competitive games unless T110s and IS-7s are locked. Maus has a job to do.
Both are great tanks, but then Tiger is a major pain util you fully research it. KT is fantastic, so is E-75. E100 is pretty good too.
The other line from 3001P is not bad either, Tiger P can ding on so many shoots (no idea how this happens tho) but then bot VK's pre Maus are so-so. Mause is SLOW.
BTW ~75% of research is common for both lines so do full reasearch on PzIV and grind both at the same time, upgrading common things on two tanks (split them, 1 thing on VK3601, another on VK3001P etc.).
I know I must be getting better at this if people are calling me a hacker now :p
I'm enjoying the Tiger, not far off II version now but probably be a while till I get it as I want to keep the original.
Thanks
i have both, i am doing better in the VK 3601 H, but the VK3001 P is pretty good as well.
I unlocked the H first, then went for the P.
both have the short 88
wait until the weekend, there is a Stalingrad special on, you never know, they may be discounted by 50%, thats how i got both last time.
Thought i would share this info with you guys, there will be polish tanks says the WoT CEO, he says it around 3:25.
Here are some concepts:
Polish medium tank
Polish heavy tank
Polish tank destroyer
Polish supply carrier
Polish super heavy concept (tier 10?)
Physics next patch after this one apparently, then British. They will probably appear about Christmas or something
I went down the VK3601 route. Enjoyed it.
Now I'm on Tiger, grinding Tiger II
I'm thinking from this is the route I will take to based on:
Think I will take the 3601 route as I prefer the look of the line overall compared to the other. I have fully researched everything on the PzIV and am at 3k exp now so am in a good position for the next tier :)
Hopefully I can grind the exp for the weekend but that may be a bit ambitious.
Thanks for all your help guys.
When you go into the store and select the nationality's it shows China as one of them but everything is blank.
Was this an aborted updated ?
Also is it just me or are there a lot more noobs on recently, or should I say experienced noobs.
Couple times last night in battles one flank was completely unguarded and the opposition just stormed through despite me flagging up the obvious issue (I was t4 arty).
In one battle there was a T4 (I think) M5 70% keeping at bay a Churchill and K-1 both at 100%. They just would not move the M5 was just sat there hiding behind a rock sniping and both t5's wouldnt move. Not firing or anything just going backwards and forwards. They were holding up the whole middle sector because of it (cant remember map the one with beach down left hand side).
They could have easily got it in a pincer movement.
If it wasnt so ludicrous it would have been funny!
Finally what I have also found annoying lately is on Assault or Encounter two or three tanks staying at <1> and 'defending' even when they are attacking on Assault !
Still love the game tho.
It is the Type 59, but it has since been removed from sale. You could get it a few months back from the gift shop and you will probably be able to in the future too.
This game seems to attract idiots, and always onto your side.
This happened to me when I decided to have a quick round before work this morning.
Moved to the right hand flank, spot 4-5 enemy tanks moving down the same flank to notice I was all on my own! Needless to say we got steamrolled because they blasted through me, the arty and then into the rear of our team even though I had pinged and called for help.
Nevermind aye :p
Everyones an expert too.
Never hit the panic button; ever. I just prefer to bend over and take it. I don't even know which one it is.
Do you guys go out of your way to troll or kill anyone in particular? I know I'm keen to kill some of our rivals and especially their leaders in randoms (when they're on the other side). Posts on the forums from people complaining they always get killed first because of their tags.
No just kill them all, keep a lookout for the bigheads and target them (usually by what they post)
I've not noticed being targeted due to tag, have sometimes noticed been targeted as I have Churchill and I (god forbid) bought it.
Although now its maxed out crew 100% with perks/skills its little darling of an earner.
I think sometime players forget buying stuff helps improve their free game.
