Forgive me boys and girls, but is this due out tonight(24th) or tomorrow(25th)?
Tomorrow, although when that'll happen isn't clear? Probably in the early evening for us.
Last year it was around 11 am wasn't it![]()
Is taking a Time Machine backup, then wiping and doing an install from USB, but picking the Time Machine to restore stuff considered clean or would that be no different to an "in place" upgrade?
I have not installed Snow Leopard or Lion for a long time, but I seem to recall you are offered various options on what you want to restore from the Time Machine (i.e. apps and/or files and/or settings).
The other alternative (which I think I did about 1 year ago) was do a full clean install and then plug in time machine disk and drag and drop back stuff.
rp2000
ML comes out tomorrow, but I am anxious to know what is the "best" way to upgrade from SL. Can anyone answer the above?
rp2000
I'd say if you were on a install that is pretty old a full wipe, zero out and install is the best port of call followed by dragging and dropping the files you need from a external.
It probably makes no odds to be honest, if you did do a clean install you're only going to fill it again with all your old settings you have/had in the TM backup. Perhaps after run some clean up actions, like some listed in this link:
http://www.chriswrites.com/2012/01/17-ways-to-speed-up-mac-os-x-lion/
You can't beat a good clean installation though! I love me a clean install.![]()
I am pretty excited about this release, I wasn't for Lion but i am this one. What do you think are the best features coming in ML?
I'm expecting an 1800 GMT launch, and will be creating my own install dvd!
PlsYup, saw that after I posted. I opened the 'reply' window and started typing but got distracted and it was about half an hour before I actually got to make the post!Instructions up! lol
It works for USB and DVD. Of course those with USB3 Will benefit over DVD.
