no one else having crashing problems ?
Not crashed once for me. Which GPU are you using ?
680 4gig ... it crashes as soon as it loads a common problem on steam forums
I'm using a 7970 and not had any issues.
  very annoying .waste of money as it cant be playedcheersvery annoying .waste of money as it cant be played
Just had a look and it does seem to be an Nvidia problem. Have you tried different drivers ?
How else would you gauge how good it is? Can't say I'm in the habit of buying PC ports just to find out if they are terrible or not. That's why reviews like this exist.You are gauging how good the PC port is purely on the single video footage?![]()
I'm quite enjoying this tbh. All the negative reviews are a bit OTT the game is fun....
The graphics look ok to me certainly no worse than any other port it looks better than the Xbox version. It runs well and the game has not crashed once for me.
Sometimes I feel people expect too much and some critics just try and rip apart for no real reason. It has a few low res textures but then what doesn't even Skyrim has but that is rated as superb..
What you have to do is, restore checkpoint, THEN you have to ALT TAB, not pause or press ESC, but ALT TAB while the game is running, and THEN change from all cores to just core0 and core1, or the opposite, from core0 core1 to all cores. Alt tab back ingame and it should be working.
from steam forums
Game doesn't even go up to 2560x1600 res, can only have 1920x1200 max.
from steam forums
