The Button thing confused me.
They called to change from Plan A to Plan B earlier, and Button said no so they stayed on Plan A, but then did the stupid 3 stop strategy screw up.
So either Plan A was a 3 stop and the just screwed up right from the off, or Plan B was the 3 stop and they managed to convince Button to switch to it later on.
Either way, when you are on hard tyres holding up the guy behind who is on the softer tyres and you can comfortably drive much further into the race knowing the guy behind had to use the slower tyre, deciding to then pit is just stupid.
Actually, thinking about it, if they were going to 3 stop from the start, I doubt they would have gone SMSM, you would expect them to use 3 stints on the Soft, so it suggests they made the decision to change to a 3 stop somewhere during the 2nd stint, and resulting in them jumping out of the way of Vettel, and then sticking Button out in traffic.
An all around screw up by the McLaren Comedy Strategy Committee, yet again.
Your right, they need to put all the eggs in the Hamilton basket, to the extent that should the situation arise, Button is asked to move over to let Hamilton through.
