** OcUK FANS! - NEW DEALS AND BUNDLE OFFER **
rjk
rjk
OcUK Staff
8 Aug 2007
UPDATED PRICING AND NEW BUNDLE DEAL HERE
Hi Guys
It gives me great pleasure to announce the arrival of the brand new OcUK Tech Labs fan.
Working in conjunction with our friends at Zaward, we have chosen their Golf 3 fan to be the basis for the OcUK Tech Labs fan.
Delivered in superb Tech Labs branded packaging with matching high quality decals on the fan hub, the OcUK ZG3-120TL is perfect as a case fan, CPU Cooler fan or a watercooling radiator fan.
This fan has been specified to be used in conjunction with a fan controller for maximum user control and performance.
OcUK Tech Labs - Zaward Golf III Fan 120mm ZG3-120TL Black/White @ £8.99 inc VAT
The OcUK ZG3-120TL has been developed in conjunction with Zaward, a world leader in computer cooling. The ZG3-120TL is a high performance fan designed for ultimate cooling potential.
The distinctive shape of the Zaward GOLF FAN has become a trademark of ZAWARD and our OcUK Tech Labs branded fan is a no compromise solution for the enthusiast seeking ultimate performance.
The G3 Golf III Fan is designed to operate at multiple speeds and is especially effective when paired with a fan controller.
The OcUK ZG3-120TL has been specifically chosen by OcUK Tech Labs to be the ultimate performance fan. The Golf III is an exclusive design only used by Zaward.
The new G3 Hexagonal dimple blade features an aerodynamic lift effect to raise airflow.
Dimension - 120 x 120 x 25mm
Fan Speed - 2000±200rpm
Bearing Type - Duro bearing
Max.Air Flow - 52.85 CFM
Noise Level - 30.9 dBA
Operation Voltage - 12V
Life Expectancy - 60,000 Hrs
Net Weight - 125g
Colour - frame: Solid Black ; Blade: White
Only £8.99 inc VAT.
ORDER NOW
What does a spanner have to do with overclocking :confused:
Techlab is our modding brand, so modified cases, custom watercooling setups. A spanner is just the image of choise to represent this, though a screwdriver is the desired tool of choice with a PC, but a spanner looks far more impressive marketing wise. :D
Noise Level - 30.9 dBA thanks Ocuk great prices but i stick with me Venoms an i thought they were loud.
They look awefuly similar to another brand of fan I've seen before...
I'm happy OcUK are moving on with their own brand of stuff though!
they are Zaward.
Zaward are the OEM for Sharkoon who I assume is what you are talking about
HOWEVER: Zaward fans that Sharkoon rebrand as their own are Golf II fans.
Zaward use the newer, better Golf III design for themselves
...and us :p
probably a well known brand with ocuk sticker on.
see above :)
These seem a bit loud for my use but looking to replace both front and back case fans on my CM690-II Advanced as near as silent as possible what do you suggest O.C ?
if you want mega quiet, then you need to be looking at noiseblocker blacksilent pro PL-1 or PL-2
they are super quiet and make decent case fan :)
or you could run these tech labs fans on a fan controller ;)
