- 10 Jan 2012
His heaven score isn't that low. A gtx 580 with the best cpu money can buy will still get a much lower score than 69fps with the settings he used.
The reason you are not seeing a difference in the games you play is simply because they are not demanding enough to test the graphics card so your cpu reaches its max output first.
The 670 will still give you approx 2 - 3 times the fps in a gpu demanding game even though your cpu may be a slight bottleneck.
Okay I'll try to explain it better.
There is 2 things that determine your fps in games. Your cpu and your graphics card. Some games are more cpu heavy and others are more gpu heavy. L4D2 is almost completely reliant on cpu power at the resolution you play at but if you increased your resolution/settings , your 280 would drop a lot whereas with the 670 fps would be unaffected. Either the gpu or cpu will reach its max fps output first.
You said you saw a 10 fps increase in world of tanks. This is likely because your 280 was slightly bottlenecking your cpu before. Now that you have a graphics card which is a lot stronger, it allows the cpu to perform at its best which in this case is 10 fps more. If you upgraded your cpu it would allow your 670 to perform a lot better ( I don't know how cpu dependent world of tanks is, but upgrading to a true quad core like a 2500k might make a big difference) If you did this with your 280 though, you would see no difference in fps as the graphics card was the limit before.
Say you are getting 45 fps now which is a 10fps increase from the 280.
The max fps in that game with a 280 is 35
with an i3 530 it's 45 (what your getting now)
with a 670 it's 100 (just a guess)
and say you changed to a 2500k it could have a max of 75 (just a guess, 670 still may not reach its max fps, but its a lot better)
It's impossible to have a perfectly balanced system as it all depends on the game. Your cpu is slightly weak for your gpu, but its not an awful combination. To allow the 670 to reach its full potential though, you would need a newer cpu such as a 2500k. Here is the i3 530 vs a 2500k
http://www.anandtech.com/bench/Product/118?vs=288 - as you can see some games benefit a lot, while others only see a small increase.
. I've compared to other peoples results and it is exactly what it should be. Don't see why someone would say there is something wrong with my computer :/
