Their FAQ does not say it won't work at all. all it says is you need the original media, doesn't say why. Ie their agreement with SOE.
And yes it works.
Downloading now
And yes it works.
why would you wnat to. its a mmorpg, but there are other servers runnig the emu code, so i assume yes, i doubt its easy though.
Just to mess around on and test stuff out![]()
A bit confused, will the trial definitely work? Their F&Q says it doesn't and you need the original media.
im stuck on the tutorial havent got enough money to pay for the training![]()
What while you were doing the tutorial on the ship?!
Right Ive installed the disks and the JTL expansion - where do i go now to set everything up?
