Listen to Fox. If your oil pressure light comes on unless it's a dodgy sensor it's bad news. No way a quick blast down a dual carriage way would cause the light to come on with a healthy engine.
Coming off the slip road an oil pressure warning message came up on the dashboard.![]()
Hope you get it sorted mate and what an upgrade from the clio!
It wasn't the A725 from the Raith to EK was it? Been up that at silly speeds and the corners are quite tight so the oil could have been at one end of the sump, unless it's baffled?
[TW]Fox;22554784 said:Who is paying for this, I thought you said you bought it from an independant?
would be good if they could provide you with before and after oil pressure figures, but i guess theyll be very vague with their answer
They're now keeping it until tomorrow because of damage to the underside...No idea how that would've happened, I haven't hit anything. Possibly a speed bump? Even then, I think I would've noticed the hit.
They think the sensor has been knocked on impact which set the light off so a few things are getting replaced and I should get the car back tomorrow.
They're paying for it all. It's a smaller audi dealership/specialist.
