- 8 Nov 2007
- Outer Space
Just noticed that the hose we've spec'd has an outer diameter of 15.9mm, yet the tube cutters spec'd only go upto 14mm? Do I need to look elsewhere for some cutters?
Apart from the price they look exactly the same to me.
Ive got angled rotaries and no issues, they do have an extra o ring in them that needs to be treated with a tiny bit of respect e.g. dont put too much lateral pressure on them
Cracking rad as long as you can fit it in the case. Comparison of the 360 version against several others here.
I have 90 degree rotaries between my two rads and haven't had any problems. They are Phobya ones and were only around £3.50 each.
fans on 1200rpm will be inaudible - that's where the black ice becomes the leader so I would say go for it!
the 560mm is also a 140mm fan version which will be quieter anyway - I've got 2 TY-140's running on my system at full 12V and they are inaudible
