Best 7950?
20 Jul 2012
Manchester
I've had my MSI 7950 for just under a week now, and while it's nice and quiet at stock, the card becomes very loud and hot once I start clocking it.
Therefore I'm looking at returning it under DSR and trying out a different one - which would you guys recommend?
I'm interested in the HIS one as a few guys have said it's the best one - however I'm scared of that blower fan going crazy once the card is OC'd.
Gigabyte Windforce, but remember that it exhausts into the case, so you'll need decent extraction and I have no idea how it will handle in crossfire. Or the Sapphire vapor X will be another good option.
I have a 932 Advanced so I should be fine for airflow :) I don't plan on using crossfire either as I've had bad experiences with it in the past.
Are there any significant differences between the Sapphire 7950 OC and the Vapour-X?
Well the "blower" on the IceQ is a huge step up from the reference type fans. The radial fan is raised up and away from the PCB and both sides are open and look at the honking big heatpipes. Honk Honk. All the reviews I can find say it's quieter than a lot and cooler than most.
Had an unsavoury time with a HIS card years ago which turned me off the brand.
OcUK handle the whole HIS Warranty
^ That sure does look nice.
Not sure how long I'd have to wait for them to be in stock though. Apparently they're overdue, hmmm.
Here's the better view of the raised up fan and shroud. Simple but brilliant idea, really. Side on the card is lovely to look at too, it's just the top down/face I'm not thrilled about.
About the overdue, when I ordered it it said the 31st. I'm going to assume it's just a late delivery and it will be in on Monday.
OK that's great, thanks for the info :)
I'll have a look into getting one when/if I sort my DSR out :D
Does anyone here have the HIS 7950? If so how does it sound under load when clocked?
No WC on these... XFX put stupid stickers at the back of the screws! Shame really as they are so good cards.
I read and listened to the videos in the review below - comparing 6 7950's and went with the Asus . Nice ,big, card and to me quiet enough (I only hear it before windows starts and ,occasionally , when gaming & even then it's not too intrusive).:)
http://www.tomshardware.com/reviews/radeon-hd-7950-review-benchmark,3207-12.html
I also have heard that the Asus PCB is of 'standard' design - assuming that this is true then it should be straight foward to watercool/add a non-standard cooler.
Therefore I'm looking at returning it under DSR and trying out a different one.
That's not a valid reason to RMA a graphics card. You've said it's absolutely fine at stock. I hope OcUK (or else where) tell you where to RAM it.
