- 17 Apr 2010
I read and listened to the videos in the review below - comparing 6 7950's and went with the Asus . Nice ,big, card and to me quiet enough (I only hear it before windows starts and ,occasionally , when gaming & even then it's not too intrusive).
http://www.tomshardware.com/reviews/radeon-hd-7950-review-benchmark,3207-12.html
I also have heard that the Asus PCB is of 'standard' design - assuming that this is true then it should be straight foward to watercool/add a non-standard cooler.
From experience coming from a 7970 DCII TOP, the problem with the ASUS card is it is not possible to do any form of voltage adjustment, additionally they seem to struggle with over clocking when compared with other reference brands. I do not know if the same is true of the 7950, but I imagine it is the same given the small difference between the 7950/7970.
Also bear in mind running a CF setup would be challenging in the future as it's a 3 slot design, so even if you could get it to fit, the temperatures would be off the scale.
My recommendation would be the HIS 7950 IceQ, very cool, nearly silent in operation and run very very well in CF (better than any other card from every review I have seen).
