- 10 Dec 2006
Ok that's put my mind at ease, I'm not sure but I think the rattle is the headphone socket.
I put it down to the camera autofocus mechanism as there was a similar (louder) noise on the One X.
When is Jellybean meant to be available for the s3?
Gents
Whats the speaker like on the S3 and the headset for music and voice calls?
Thanks
New OTA update for 4.1.1 XXDLI1, Release Date: 03-09-2012 (Region: BTU)
from XDA:
* transparency bug still there
* swiftkey works
* led brightness reduced(seems this will be the same for future)
* new green icon for registering updates
* wifi is working good
* smoothness on par with lh9
* same gallery(not the new one like note 2)
I've just checked the one I used for the S2 and it doesn't appear to work. I think I remember others saying this was the case
**EDIT** Has anyone tried one of these? It actually looks like a better option as you don't need a seperate HDMI cable. It says it's compatible with the S3, I might give it a go...
**EDIT2** I see some comments saying it doesn't work on the S3![]()
Has anyone used an SGS III as a hotspot to tether with an iPad?
I've not found anything conclusive to say it works, but I assume it should do?
MHL Pin layout is slightly different on the S2 compared to S3 hence the compatibility issues. Best bet is to get the official s3 one. Although wireless is the way forward, but the box hasn't been released yet.
I'm not sure what the next Nexus will really be for? Usually it's to launch the next version of Android...
Key lime pie unless they've shifted to yearly updates (two per year so far)
On the verge of installing the latest JB Rom. Ive backed up and its recommended to do a full wipe when installing. If I have problems can I just reinstall the backup and return to normal?
Im certain I can just reinstall but the more I think about it the more im confused. I dont want to lose my stuff![]()
