And the wheels on the Canyon. Can't wait to take her for a decent spin Tue/Wed
Yay! Found another one! ******* LOL!![]()
Is there a jack of all trades road bike? would like something fairly comfortable that I can use for long distances as well as climbing and sprints, really getting into watching road cycling and triathlon on eurosport and wouldn't mind doing a shorter (sprint) triathlon myself at some point in the future. This would be my first road bike btw.
)Naughty gear to leave the bike in! I'd have the QR heads on the other side too![]()
Good shout on the QR though will swap them round when I pick up the bike in a couple of hours. QR Clamp pointing to the rear or upwards?
I'm on a compact and thinking of going to a double at some point. Top end will mean I'll be hitting the same speed but be further up the block a bit.
I tend to ignore the top few gears on the 34t ring though as I can spin to easily, on the 39 I'll make a lot more use of the gears in that before moving up to the 53t. I also hate knowing I have an easier gear to go to on the granny gear as it makes me want to use it, on a 39/25 I would need to just push myself harder.
Watching Contador and Rodriguez in the Vuelta has really inspired me to want to do more climbing.
Those guys are absolute machines.
How long do you guys think i should wait before chasing Canyon up? heard nothing so far from them, after emailed this time yesterday
I've got a donor road bike with full Ultegra groupset that the frame is too small for me so I want to transfer over the groupset, stem, handlebars and a set of brand new Giant PR2 wheels from my Defy to a steel winter bike that I can deck out with full mudguards and potentially a pannier rack for touring/commuting.
I've seen the Planet X Kaffenback swap out frame that looks decent value, if a little heavy, for £180 including the fork.
Are there any pitfalls to swapping the components from my Fondriest to the Kaffenback?
The things I've thought of to date are:
- Seatpost size
- Front deraileaur clamp size (shims?)
- Require long reach brake calipers (Shimano R650?) Will these fit the Kaffenback?
- Which mudguards with (at least 28mm tyres) Crudcatchers/SKS raceblades/A N Other?
Anything else anyone can think of? I can take the frame to my LBS to swap the bottom bracket over and fit the fork and headset.
How much are decent headsets?
When I have emailed them @ the uk address I have received responses within a couple of hours. Otherwise 24-48 hours as a general rule of thumb is usually a reasonable time to expect a response by.
I would get an email over to the German arm though and cc the uk address again. But I know the UK is only staffed by a couple of guys and they were probably @ Eurobike which has only just wrapped up.
A red square? Awesome, I've only ever seen those online.
