Depends on class really, my WD sits on 40-45k depending on gear but I cut through act 3 pretty quickly now thanks to 102 mana regen even though i dropped like 17k DPS compared to using the Skorn that dropped.
Has anyone come across any plans lately? I've not seen a single drop (that wasn't Exalted and 1 of the pieces you get given at lvl10 Blacksmith) for a very long time.
What do we consider good dmg these days?
My Monk is sitting at around 42k which I know isn't fantastic
Found my first legendary after patch.insta sold for 18mil.
Sounds pretty good for a Monk? My housemate is around 22k at the moment and whilst he can stay alive in act3 against most mobs it takes him ages working through it
I'm back up to 60k dps with my Barb again, trying to work my all resist up so Act3 isn't quite as tricky as it can be against some mobs.
If it literally insta sold you probably had it on too cheap. What was it?
22k. I remember those days. It is surprisingly easy though to hit 40k, you don't need millions. You just need to make sure you have some decent crit chance/dmg gear with fairly high-ish Dex. I try and go for attack speed also where I can. I'm trying to get a ring at the moment but the one I want is over 10mln which I feel is a lot. Since I play coop mostly the mobs go down fast enough, i'll wait it out for more to hit the market.
I noticed in Act III it was hard to stay alive around 20k-ish dmg because I couldn't take down elites fast enough on my own. That and life steal on low dmg = low hp back. Your friend is doing well - more so if he is playing solo. I didn't realise how important stacking resistance was until inferno too. A huge bonus to monks with the passive that boosts all others. But when you hit high enough dmg you can change that mantra to another that helps with even more dmg
It may have been very well priced too. I don't mind "losing" a few gold pieces on a sale if the item sells fast.
-snip-
i might be interested in that mate, if its any good for the WW setup?![]()
really enjoyed my monk up to hell, now im really finding it quite tough!
anyone got a few tips? must have talents and is it better to have a 1h+shield? im using the passive that adds dodge for dual wielding, not sure which is better tbh (apart from the added armor from the shield but lower dps?)
Yes mate its only useful in WW setup,
Resists are mandatory, but being a monk, you can use the trait that lets you gain resist all from 1 trait, so you can just stack 1 resist type.
I haven't used a shield for .... ages. I just use the extra dodge and dual wield. Quite happily farming act 3 (when I can be arsed) with only the occasional death.
