I've tried this with a Sapphire 7950 Vapor X. It doesn't work....
I tried from a fresh windows install.
I also attempted to place the dll files in sysWow64 manually, with UAV disabled, but it says I don't have permission. I tried to edit the security tab of sysWOW64 properties, but it simply said access denied. Glad to see win7 hasn't lost Vista charm.
Is there any hope of me unlocking voltage?
I've got the same card and it worked fine.
I had to run the /xcl thing twice. The first time it told me I needed to reset then the second time it said that clocks were unlocked.
Then I had to enable voltage setting in the options of afterburner.
unlocked everything
