Show Us Your Motors!
Yeah I know, they're as good as any other to hold the R888s for track/sunday afternoon use.
I can't imagine parting with £lol for just those rims though.
Took the springs out. Rides fine!
Nah.. cheapo ebay coilovers. Bit of a bumpy ride but not half as bad as I was expecting/had read about. Can go much lower but then it just sits on the bump stops.
Currently I'm not bottoming out the suspension even on very harsh terrain, but it's low enough to make pillow humps a pain so chances are I'll be lifting it a little before long.
Ah right. I had cheap ebay coilovers on mine, great for about 6 months after i bought the car then started making odd noises and the handling felt no where near as good. Got MeisterRs to replace them and even thiugh they cost more you can tell the difference.
If you are going to raise the height try get the bottom wishbone parallel with the ground
Where is that last one? :eek:
Looks like something from Gran Turismo.
Stelvio Pass, Italy :)
