- 5 Sep 2008
http://www.telephonesonline.co.uk/s...i-3g-wifi-8mp-camera-smartphone-sim-free.html
£360
Recommended by Paul from MoDaCo
£360
I'm on Checkrom at the moment. Rock stable ICS rom with a nice kitchen app for flashing mods easily
http://forum.xda-developers.com/showthread.php?t=1738527
Gonna stick with this until JB.
Probably because the access speed of the internal storage will be faster than the sd card
Can anybody confirm this?
Naturally the speed of a class 10 card will be fast enough not to notice any difference, I was merely giving a reason for the massive price difference![]()
Sorry this has probably been asked A TON of times - does anybody know where the cheapest place to buy one of these unlocked to be used with my ladies Orange sim from her Desire which is on its last legs, seen them for about 426 on RF...
Hi
When I take pictures they save to a folder called DCIM on my sd card.
What I need to know is , is it possible to take a picture and have it saved to a different folder on the sd card and then easily categorised in gallery to view?
For instance if I go on holiday I would like all pictures taken to be saved in there own folder so they can be found easily.
cheers![]()
Sadly the only option from within the camera app itself is just to save them to the internal or external memory. There may be apps that can do this for you, but I've not seen any.
All I can suggest would be at the start of your holiday to move all the photos you already have into a new folder in the same location as the DCIM folder. After the holiday you can rename the DCIM folder (with you holiday photos in) to Holiday (or whatever you want), and rename the folder with all your other photos in back to DCIM.
Bit of hassle I admit, but it will get you what you want.
Question :
With myself being on Tmobile, and everything everywhere being owned being them. Is my GS3 LTE capable and will I get it??
