- 3 Oct 2009
- Wales
Got my update.... wooohooo.... so what does it give me then?G
- faster throughouta bit smoother as well especially for sense stuff
- more free RAM
- wifi strength has definitely improved as well as the speeds slightly (can't test just how much stronger the signal is, as it is raining outside and that is the only time when my wifi is the weakest i.e. 1-2 bars)
- signal strength with "GSM only" connection has improved, getting full bars most of the time now (although it still goes back to 3 or so every now and then and is why there is virtually no difference in the screens below), however, it has vastly improved when I have a "WCDMA only" connection as you can see
- data speeds aren't much better although the upload is higher and the ping is a bit better
- browsing seems much quicker
- sense browser has an updated UI, which is much nicer and more functional, the double tap to zoom in renders the page a lot quicker
- as we all know, the 3 dot menu button tweak
- EA games, where we can get dead space for free (looks great and works very well on the S)
- I think multi-tasking is a bit better as well
Wifi strength and no 3 button menu is most noticeable for me. Full wifi the majority of the time compared to 0/1 bars. Also i seem to be getting an extra bar of mobile signal as well.
G
), the only real issue I had was the 3 dot menu button and signal not being very consistent, but after the update I would say that everything has been improved in my experience so far and that there isn't much left to be improved upon apart from improving the signal even more as well as smoothness and fixing the camera with regards to some colours being too over saturated i.e. reds and also improving 1080P recording (doubt this will ever happen though), although the camera may have improved with the new update, I haven't tested it yet....
