I'd like to see Rich do an Extreme run on just one of his cards.
I did if you look on page 7 or 8. By some of the loose definitions of OK frame rates going on in this thread then a single overclocked 680 can just about handle Extreme AA as well... just.
Use the beta's. Will check for you in a bit.
VRAM usage was around 1000-1100 so not an issue in this game.
Updated run with Hi-Res Textures:
Not bad Rusty, could use some improvement though.
I agree with you though, i wouldn't class your experience as smooth for two reasons, your average is well below 50 and your minimum is below 30.
However your SLI results look decent.![]()
I wouldn't class yours or mine as smooth!
It really is smooth, probably because its a amd gaming evolved title so it just runs better/smoother on AMD hardware.
Can a game run smoother than its frame rate?
You said yours is not smooth, i just agreed judging by your fps.
If i run my 7970 at stock then yes, 29fps minimum and 46 average is not smooth.
Do you just use a single 1080p screen? Isn't 680 SLI slightly overkill?
How is it overkill? He's not getting remotely near a 120hz average frame rate.
Chips i think its nigh time you posted some benches from your xfire setup.![]()
Is it any good? i'm looking for something new, i'm sick of BF3 with the Hacking and bad net code.
Sleeping Dogs? Yeah, it's a good game, but a completely different kettle of fish to BF3.
Honestly don't understand the hacker mentality. What's the point in getting all those kills when none of them are down to your own skill?
I'm crap at BF3, but I just accept it and try to improve![]()
