- 29 Dec 2004
- Shepley
There's a jumble sale in a few weeks about 25 miles from me. I'd be quite tempted to bob along!
Whereabouts?
If you move the wheel past the sensor you should hear a faint clicking noise. Then you know if it is lined up correctly and registering wheel movement.
I never set the wheel size on mine, it just automatically worked that one out somehow!
***** its cold this morning!
arm and leg warmers werent enough! need to invest something warmer!
And do we know what distance we would be making??
And most important : when would we meet? Few weeks time?
I checked and moved it along the spoke slightly, as the notch on the sensor arm is towards the end. I had it setup in the middle of the arm.
It still registered with the green LED when pedalling so I thought it was correct, perhaps when pedalling at speed it was a bit dodgy. I'll probably be able to get out on the bike on Tuesday or Wednesday to test it, working away and it might be the start of the Water Polo season on Tuesday.
Last winter I managed to go through with long sleeves base layers from HH and just altura rain jacket. So not much considering that those base layers are pretty thin.
Yesterday I wore:
Bib shorts
Arm + Leg warmers
Short sleeved Jersey
Thermal T-shirt
Altura Night vision jacket
Everything bar the thermal tshirt (which was dry) was pretty much soaked (sweat or condensation?) when I got home... I don't think my jacket is very breathable.
I can't believe how nice the weather is here today yet I'm still stuck without the bike! Specialized have told the lbs to give me a new saddle under crash replacement, but the lbs won't give it to me.![]()
my first ride (although i think the seat isnt in the correct position still)
and ignore the HR i didnt have it on me
http://app.strava.com/activities/24972681
Not bad, but you need to get your cadence up, 60 is way too low, will destroy your knees and make it a lot tougher to ride.
Anything less than 80 feels really tough for me, with a high 80 feeling optimal on the flat, 90+ uphill if I have a low enough gear to use sitting.
Whereabouts?![]()
