It's pretty well known that BF3 favours Nvidia cards![]()
That used to be the case, but it's considerably more even now
I hate when they do this.
Will get 7950 than.
That used to be the case, but it's considerably more even now![]()
1.26v stock? Wtf, bet the card was throttling.![]()
The card had a default voltage of 1.26v lol.
Your best bet, £20 more than the cheapest ones, but i don't believe in going for the cheapest, not for the sake of £20, get the one with the custom PCB and top notch rep.
Tally ho old chap.![]()
Yup, no surprises there
@ LtMatt, Sapphire and HIS do look like they use pretty low binned GPU's at times, running @ 1.26v is pretty horrendous for a 7970. that card will have been a total shambles at any clock.
I know someone with a HIS 7870 that's like that, his performance is way below mine, even a couple of entry level ASUS ones don't seem to measure up.
I think something must have been wrong with your system somewhere JD to come to the conclusion that a 670 with x4 aa is smoother than a 7970 with AA off and shadows only on high.
That's definitely not something ive experienced, but i wish you all the best with your next purchase.
Some fella posted these in another thread just today, seems to indicate things are pretty close now.
http://media.bestofmicro.com/A/1/342505/original/battlefield 1920.png
http://media.bestofmicro.com/A/2/342506/original/battlefield 2560.png
http://gamegpu.ru/images/stories/Test_GPU/Action/Battlefield 3 Armored Kill/test/b3 ac 1920.png
http://gamegpu.ru/images/stories/Test_GPU/Action/Battlefield 3 Armored Kill/test/b3 ac 2560.png
I wanted the 7970 as well as Crysis and Metro are games I've yet to play which run a lot better on AMD cards but I'm now settling on 3D which is better suited to Nvidia. Don't worry though, I'm always an AMD man
. Maybe I'll buy one to test with and take the loss on Ebay but for now I think I'm done deciding after sending back both the 670 and 7970 back. Just want to game
.That's what he said.
Enough CPU power?. 4 threads @ 4.2Ghz?.
.Have a look here. http://forums.overclockers.co.uk/showthread.php?t=18443672
You're right though. My card was a Vapor-X reject.
Probably Matt. The Heaven score was kinda on point wouldn't you say at 1175Mhz?. It was 2101. It's nothing to do with remaining drivers or anything as I nuke everything prior to installing cards and I test friends cards in my system frequently. So it's not user error. Also the only games installed on my system were BF3 and Pro Evolution as it was a new install after buying my Samsung 830. However why is there no problem with the GTX 670 just weeks apart?. I went back to my 6950 without a problem also so that also indicates no problems elsewhere. I just find it strange you thinking it's something to do with my system yet my system is fine with the 6950 and GTX 670 but not so good with the 7970?.
If it was throttling in BF3, fair enough, but to not do so on Heaven confuses that conclusion.
End of the day I'm an AMD man when it comes to graphic cards. I'm giving my honest opinion on my findings here and my systems stability is not in question due to listed reasons above. This was mainly on 64 man servers and BF3 is on my SSD drive. If it was maybe because I wasn't running HT or something then fair enough but I doubt that's the case mate otherwise I'd have seen the same with the 670.I wanted the 7970 as well as Crysis and Metro are games I've yet to play which run a lot better on AMD cards but I'm now settling on 3D which is better suited to Nvidia. Don't worry though, I'm always an AMD man
Yes it's default was 1.26v. http://forums.overclockers.co.uk/showpost.php?p=22808195&postcount=11
(this is a joke don't start flaming me please)BF3 does benefit from HT, it loves cores/threads but i doubt that was the reason for your less than stellar performance.
Are you sure? Not a single CPU scaling review of BF3 on the entire internet shows this:
http://www.techspot.com/review/458-battlefield-3-performance/page7.html
This is one of very few games that is purely GPU bottlenecked.
It's okay guys just buy a 7850 and overclock it. I promise it does 60+fps on BF3 Ultra 4xMSAA. 12.9 beta's add 20fps to the minimums I swear...
High end SLI it helps (as above).
Are there any reviews showing this? I've never seen any review on BF3 showing much improvement from CPUs.
.who is he?![]()
