- 21 Sep 2009
- London
Thanks
Idle sits at 50C with slow fans on the rad and under load at 4.6GHZ @ 1.32V, it goes to 62C. At 5GHZ with 1.495V under load, it goes to ~75C (I ran prime95 for 30 mins I think). I expect when I have the 2 GPU's cooled with the extra 240 rad, it will be a little warmer under load but not by much.
50ºc on idle is too high mate, there's something wrong as 35ºc at idle is possible with an air cooler let alone wc. The recommended max for the 3930k is 72.6ºc
http://communities.intel.com/thread/27814
but then you read more and more and ambient room temp does play a big part and proves it with the door open. Maybe when the wife is out in the middle of winter, I will see what I can get down to but for now, I am happy.
I just turned the pump upto full and being the clumsy oaf that I am, I caught my hand on the fan
