HTC will never change, they'll always get 80% right and 20% wrong.
Quote of the thread...
Sad, but true.
2035AD HTC Announces its new Smartphone, the Desire OneOneOne Z
- 5" screen with 15000x10000 resolution, capable of transmitting images directly into the brain
- 64 Core 'Turbo Cray' CPU, 25 times faster than any other smartphone in 2035AD
- 28 Gigapixel camera that takes photos triggered by the power of thought
- 64 Terabytes internal storage
- Automatic satellite connection allowing 32000Kbit/sec download speed from anywhere on the planet
- 900 mAh battery
LOL2035AD HTC Announces its new Smartphone, the Desire OneOneOne Z
- 900 mAh battery
I don't really see any reason at all to have 1080p resolution on a device this size... I don't want screen resolution to wind up being the same thing as MP counts in cameras
That battery size makes baby Jesus cry
I guess I am mostly happy that someone has manned up and made a handheld 1080p display that bums the iFail screen.
It is also promising that HTC have fit the display into a device that is pretty much the same size as the current 4.7" phones.
Can't be too long before others follow suite...
Gief Motorola RAZR FHD MAXX Nexus in carbotanium housing?
When it comes to 1080p on a smartphone, he admits that it might not matter for the most casual users. "For some people, it is possible to tell the difference if we were to sit down and study a [1080p] display and a [720p] display, side-by-side," he said in a phone interview with Ars. "If you’re really a fanatic and you study images, or you have some professional applications and you’re really into displays, then it may make a visual difference for you."
Where a 1080p smartphone display could really make an impact is with computer-generated content—that is, the user interface, buttons, and text. "Only computer-generated images make full use of the pixel resolution of the display," says Dr. Soneira. "For graphics and text, maybe you want that kind of sharpness." Like desktop computers, smartphone displays can also utilize sub-pixel rendering, which helps improve the visual sharpness of computer-generated graphics.
It seems it might not be 2020 mAh after all - as Techradar are reporting it as being 2200 mAh however that's still (as they say) on the small side given the generous screen size and res!
2020 is such an odd amount, are we sure it isn't 2200? Though I guess this is HTC...
Wasn't this on the BBC with 440ppi density, with a screen that is more efficient, hence the smallish battery.
