im having lots of problems with the new launcher it keeps closing down minecraft and giving an error this is the error that i am getting
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000007feeaa16220, pid=1528, tid=6504
# JRE version: 6.0_17-b04
# Java VM: Java HotSpot(TM) 64-Bit Server VM (14.3-b01 mixed mode windows-amd64 )
# Problematic frame:
# C [OpenAL64.dll+0x6220]
# If you would like to submit a bug report, please visit:
http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000067492800): JavaThread "Thread-14" daemon [_thread_in_native, id=6504, stack(0x0000000075ce0000,0x0000000075de0000)]
siginfo: ExceptionCode=0xc0000005, writing address 0xffffffff87d8eeb0
Registers:
EAX=0x0000000076e07670, EBX=0xffffffff87d8ee90, ECX=0x000000006c870000, EDX=0x0000000000000088
ESP=0x0000000075ddf470, EBP=0x000000006c87c850, ESI=0x00000000ffffffff, EDI=0x0000000000000022
EIP=0x000007feeaa16220, EFLAGS=0x0000000000010246
Top of Stack: (sp=0x0000000075ddf470)
0x0000000075ddf470: ffffffff87d8ee90 00000000ffffffff
0x0000000075ddf480: 0000000007f10d58 0000000075ddf4e8
0x0000000075ddf490: 0000000075ddf630 0000000002691588
0x0000000075ddf4a0: 0000000007f339d0 0000000075ddf520
0x0000000075ddf4b0: 000000004b308c00 0000000000000022
0x0000000075ddf4c0: 0000000087d8ee90 0000000000000000
0x0000000075ddf4d0: 0000000008075d38 000000004b308bc0
0x0000000075ddf4e0: 0000000075ddf4e0 0000000000000000
0x0000000075ddf4f0: 0000000075ddf550 0000000007f364a0
0x0000000075ddf500: 0000000000000000 0000000007f339d0
0x0000000075ddf510: 0000000000000000 0000000075ddf540
0x0000000075ddf520: 0000000075ddf598 0000000002685ac2
0x0000000075ddf530: 0000000007f363e8 000000000268de58
0x0000000075ddf540: 0000000087d8ee90 0000000000001009
0x0000000075ddf550: 000000006c87c850 0000000075ddf558
0x0000000075ddf560: 0000000007f19f67 0000000075ddf5b0
Instructions: (pc=0x000007feeaa16220)
0x000007feeaa16210: 04 01 00 00 00 48 89 45 68 c7 45 70 01 00 00 00
0x000007feeaa16220: ff 43 20 eb 0a c7 85 74 01 00 00 30 10 00 00 89
Stack: [0x0000000075ce0000,0x0000000075de0000], sp=0x0000000075ddf470, free space=1021k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.openal.AL10.alSourcei(III)V+0
j paulscode.sound.libraries.ChannelLWJGLOpenAL.attachBuffer(Ljava/nio/IntBuffer
Z+39
j paulscode.sound.libraries.SourceLWJGLOpenAL.play(Lpaulscode/sound/Channel
V+362
j paulscode.sound.Library.play(Lpaulscode/sound/Source
V+72
j paulscode.sound.Library.play(Ljava/lang/String
V+89
j paulscode.sound.SoundSystem.CommandPlay(Ljava/lang/String
V+12
J paulscode.sound.SoundSystem.CommandQueue(Lpaulscode/sound/CommandObject
Z
J paulscode.sound.CommandThread.run()V
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0000000067498000 JavaThread "Client write thread" daemon [_thread_blocked, id=5908, stack(0x0000000079590000,0x0000000079690000)]
0x0000000067496800 JavaThread "Client read thread" daemon [_thread_in_native, id=9048, stack(0x0000000079090000,0x0000000079190000)]
0x0000000067497000 JavaThread "File IO Thread" daemon [_thread_blocked, id=2728, stack(0x0000000079190000,0x0000000079290000)]
0x0000000067493800 JavaThread "Thread-15" daemon [_thread_blocked, id=4056, stack(0x0000000076cd0000,0x0000000076dd0000)]
=>0x0000000067492800 JavaThread "Thread-14" daemon [_thread_in_native, id=6504, stack(0x0000000075ce0000,0x0000000075de0000)]
0x0000000067491800 JavaThread "Thread-13" daemon [_thread_in_native, id=7696, stack(0x00000000762d0000,0x00000000763d0000)]
0x0000000067490000 JavaThread "Minecraft main thread" daemon [_thread_blocked, id=7352, stack(0x000000006c330000,0x000000006c430000)]
0x0000000067492000 JavaThread "Timer hack thread" daemon [_thread_blocked, id=6808, stack(0x00000000696b0000,0x00000000697b0000)]
0x000000006748f000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=7868, stack(0x00000000694a0000,0x00000000695a0000)]
0x000000006748e800 JavaThread "DestroyJavaVM" [_thread_blocked, id=7832, stack(0x0000000002580000,0x0000000002680000)]
0x000000006748d800 JavaThread "TimerQueue" daemon [_thread_blocked, id=7384, stack(0x00000000692a0000,0x00000000693a0000)]
0x000000006837e000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=5736, stack(0x000000006c430000,0x000000006c530000)]
0x0000000067fa3800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=6664, stack(0x0000000068fb0000,0x00000000690b0000)]
0x000000006807f800 JavaThread "AWT-Shutdown" [_thread_blocked, id=5316, stack(0x0000000068eb0000,0x0000000068fb0000)]
0x000000006807d000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=8056, stack(0x0000000068c50000,0x0000000068d50000)]
0x00000000674a3800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=5312, stack(0x0000000067c80000,0x0000000067d80000)]
0x000000006748d000 JavaThread "CompilerThread1" daemon [_thread_blocked, id=3488, stack(0x0000000067b80000,0x0000000067c80000)]
0x0000000067477800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=8096, stack(0x0000000067a80000,0x0000000067b80000)]
0x0000000067473000 JavaThread "Attach Listener" daemon [_thread_blocked, id=6244, stack(0x0000000067980000,0x0000000067a80000)]
0x0000000067472000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2272, stack(0x0000000067880000,0x0000000067980000)]
0x0000000067425000 JavaThread "Finalizer" daemon [_thread_blocked, id=3672, stack(0x0000000067780000,0x0000000067880000)]
0x0000000067424800 JavaThread "Reference Handler" daemon [_thread_blocked, id=4716, stack(0x0000000067680000,0x0000000067780000)]
Other Threads:
0x0000000067421800 VMThread [stack: 0x0000000067580000,0x0000000067680000] [id=6300]
0x00000000674a5800 WatcherThread [stack: 0x0000000067d80000,0x0000000067e80000] [id=6968]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 94656K, used 60221K [0x0000000047fe0000, 0x0000000054af0000, 0x0000000066a80000)
eden space 86784K, 60% used [0x0000000047fe0000,0x000000004b309b58,0x000000004d4a0000)
from space 7872K, 99% used [0x0000000053980000,0x00000000541258f8,0x0000000054130000)
to space 9984K, 0% used [0x0000000054130000,0x0000000054130000,0x0000000054af0000)
PSOldGen total 208192K, used 161783K [0x000000000aa80000, 0x00000000175d0000, 0x0000000047fe0000)
object space 208192K, 77% used [0x000000000aa80000,0x000000001487dd10,0x00000000175d0000)
PSPermGen total 68672K, used 48404K [0x0000000005680000, 0x0000000009990000, 0x000000000aa80000)
object space 68672K, 70% used [0x0000000005680000,0x00000000085c5300,0x0000000009990000)
Dynamic libraries:
0x0000000000400000 - 0x000000000042e000 C:\Program Files\Java\jre6\bin\javaw.exe
0x0000000077ae0000 - 0x0000000077c89000 C:\Windows\SYSTEM32\ntdll.dll
0x00000000779c0000 - 0x0000000077adf000 C:\Windows\system32\kernel32.dll
0x000007fefd540000 - 0x000007fefd5ac000 C:\Windows\system32\KERNELBASE.dll
0x000007fefeff0000 - 0x000007feff0cb000 C:\Windows\system32\ADVAPI32.dll
0x000007fefdd60000 - 0x000007fefddff000 C:\Windows\system32\msvcrt.dll
0x000007fefd920000 - 0x000007fefd93f000 C:\Windows\SYSTEM32\sechost.dll
0x000007feff0f0000 - 0x000007feff21d000 C:\Windows\system32\RPCRT4.dll
0x0000000077400000 - 0x00000000774fa000 C:\Windows\system32\USER32.dll
0x000007fefd940000 - 0x000007fefd9a7000 C:\Windows\system32\GDI32.dll
0x000007fefdd00000 - 0x000007fefdd0e000 C:\Windows\system32\LPK.dll
0x000007fefeea0000 - 0x000007fefef69000 C:\Windows\system32\USP10.dll
0x000007fefdbc0000 - 0x000007fefdbee000 C:\Windows\system32\IMM32.DLL
0x000007fefdbf0000 - 0x000007fefdcf9000 C:\Windows\system32\MSCTF.dll
0x000000006d7f0000 - 0x000000006de4d000 C:\Program Files\Java\jre6\bin\server\jvm.dll
0x000007fefb590000 - 0x000007fefb5cb000 C:\Windows\system32\WINMM.dll
0x000000006d760000 - 0x000000006d76e000 C:\Program Files\Java\jre6\bin\verify.dll
0x000000006d3b0000 - 0x000000006d3d7000 C:\Program Files\Java\jre6\bin\java.dll
0x000000006d310000 - 0x000000006d31a000 C:\Program Files\Java\jre6\bin\hpi.dll
0x0000000077ca0000 - 0x0000000077ca7000 C:\Windows\system32\PSAPI.DLL
0x000000006d7b0000 - 0x000000006d7c2000 C:\Program Files\Java\jre6\bin\zip.dll
0x000000006d000000 - 0x000000006d1c1000 C:\Program Files\Java\jre6\bin\awt.dll
0x000007fefb020000 - 0x000007fefb091000 C:\Windows\system32\WINSPOOL.DRV
0x000007fefd9b0000 - 0x000007fefdbb3000 C:\Windows\system32\ole32.dll
0x000007fefde80000 - 0x000007fefec08000 C:\Windows\system32\SHELL32.dll
0x000007fefef70000 - 0x000007fefefe1000 C:\Windows\system32\SHLWAPI.dll
0x000007fefbd40000 - 0x000007fefbf34000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\comctl32.dll
0x000007fefb570000 - 0x000007fefb588000 C:\Windows\system32\DWMAPI.DLL
0x000007fefb980000 - 0x000007fefb9d6000 C:\Windows\system32\uxtheme.dll
0x0000000068b60000 - 0x0000000068c1e000 C:\Program Files\DigitalPersona\Bin\DpoFeedb.dll
0x000007fefd740000 - 0x000007fefd817000 C:\Windows\system32\OLEAUT32.dll
0x000007fefc3d0000 - 0x000007fefc3dc000 C:\Windows\system32\VERSION.dll
0x000007fefc6f0000 - 0x000007fefc70e000 C:\Windows\system32\USERENV.dll
0x000007fefd370000 - 0x000007fefd37f000 C:\Windows\system32\profapi.dll
0x000007fefd2a0000 - 0x000007fefd2af000 C:\Windows\system32\CRYPTBASE.dll
0x000000006d2a0000 - 0x000000006d30b000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x000007fee8110000 - 0x000007fee830f000 C:\Windows\system32\d3d9.dll
0x000007fef2b10000 - 0x000007fef2b17000 C:\Windows\system32\d3d8thk.dll
0x000007feeecb0000 - 0x000007feeecbd000 C:\Windows\system32\atiu9p64.dll
0x00000000699f0000 - 0x0000000069eef000 C:\Windows\system32\atiumd64.dll
0x000000006a0e0000 - 0x000000006a3fb000 C:\Windows\system32\atiumd6a.dll
0x000000006d600000 - 0x000000006d617000 C:\Program Files\Java\jre6\bin\net.dll
0x000007fefdd10000 - 0x000007fefdd5d000 C:\Windows\system32\WS2_32.dll
0x000007fefee90000 - 0x000007fefee98000 C:\Windows\system32\NSI.dll
0x000007fefcba0000 - 0x000007fefcbf5000 C:\Windows\system32\mswsock.dll
0x000007fefcb90000 - 0x000007fefcb97000 C:\Windows\System32\wship6.dll
0x000000006d620000 - 0x000000006d62b000 C:\Program Files\Java\jre6\bin\nio.dll
0x000007fefab50000 - 0x000007fefab65000 C:\Windows\system32\NLAapi.dll
0x000007fef7720000 - 0x000007fef7735000 C:\Windows\system32\napinsp.dll
0x000007fef7700000 - 0x000007fef7719000 C:\Windows\system32\pnrpnsp.dll
0x000007fef76e0000 - 0x000007fef76f0000 C:\Windows\system32\wshbth.dll
0x000007fefca20000 - 0x000007fefca7b000 C:\Windows\system32\DNSAPI.dll
0x000007fef76d0000 - 0x000007fef76db000 C:\Windows\System32\winrnr.dll
0x000007fef91d0000 - 0x000007fef91ff000 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x000000006a070000 - 0x000000006a0a5000 C:\Program Files\Bonjour\mdnsNSP.dll
0x000007fefa680000 - 0x000007fefa6a7000 C:\Windows\system32\Iphlpapi.DLL
0x000007fefa670000 - 0x000007fefa67b000 C:\Windows\system32\WINNSI.DLL
0x000007fefcc00000 - 0x000007fefcc17000 C:\Windows\system32\CRYPTSP.dll
0x000007fefc900000 - 0x000007fefc947000 C:\Windows\system32\rsaenh.dll
0x000007fefa4f0000 - 0x000007fefa543000 C:\Windows\System32\fwpuclnt.dll
0x000007fef9130000 - 0x000007fef9138000 C:\Windows\system32\rasadhlp.dll
0x000007fefc4f0000 - 0x000007fefc4f7000 C:\Windows\System32\wshtcpip.dll
0x000000006c010000 - 0x000000006c075000 C:\Program Files\WIDCOMM\Bluetooth Software\btmmhook.dll
0x0000000180000000 - 0x0000000180048000 C:\Users\user\Desktop\LinkTartLauncher_v3.2\mcp_data\.minecraft\bin\natives\lwjgl64.dll
0x000007feeada0000 - 0x000007feeaebd000 C:\Windows\system32\OPENGL32.dll
0x000007fef0100000 - 0x000007fef012d000 C:\Windows\system32\GLU32.dll
0x000007feeaca0000 - 0x000007feead91000 C:\Windows\system32\DDRAW.dll
0x000007fef74c0000 - 0x000007fef74c8000 C:\Windows\system32\DCIMAN32.dll
0x000007fefecb0000 - 0x000007fefee87000 C:\Windows\system32\SETUPAPI.dll
0x000007fefd4c0000 - 0x000007fefd4f6000 C:\Windows\system32\CFGMGR32.dll
0x000007fefd5b0000 - 0x000007fefd5ca000 C:\Windows\system32\DEVOBJ.dll
0x000000006d3f0000 - 0x000000006d3f7000 C:\Program Files\Java\jre6\bin\jawt.dll
0x000007fefa970000 - 0x000007fefa978000 C:\Windows\system32\atig6pxx.dll
0x0000000072330000 - 0x0000000073744000 C:\Windows\system32\atio6axx.dll
0x000007fef74f0000 - 0x000007fef74fa000 C:\Windows\system32\atig6txx.dll
0x00000000697b0000 - 0x0000000069807000 C:\Windows\system32\atiadlxx.dll
0x000007fefd500000 - 0x000007fefd539000 C:\Windows\system32\WINTRUST.dll
0x000007fefd5d0000 - 0x000007fefd73a000 C:\Windows\system32\CRYPT32.dll
0x000007fefd410000 - 0x000007fefd41f000 C:\Windows\system32\MSASN1.dll
0x000000006c660000 - 0x000000006c676000 C:\Users\user\Desktop\LinkTartLauncher_v3.2\mcp_data\.minecraft\bin\natives\jinput-dx8_64.dll
0x000007feed910000 - 0x000007feed94c000 C:\Windows\system32\DINPUT8.dll
0x000007fefb9f0000 - 0x000007fefb9fb000 C:\Windows\system32\HID.DLL
0x000000006c6a0000 - 0x000000006c6b4000 C:\Users\user\Desktop\LinkTartLauncher_v3.2\mcp_data\.minecraft\bin\natives\jinput-raw_64.dll
0x000007feeaa10000 - 0x000007feeab32000 C:\Users\user\Desktop\LinkTartLauncher_v3.2\mcp_data\.minecraft\bin\natives\OpenAL64.dll
0x000007fefb5d0000 - 0x000007fefb658000 C:\Windows\system32\dsound.dll
0x000007fefc4a0000 - 0x000007fefc4cc000 C:\Windows\system32\POWRPROF.dll
0x000007fefec10000 - 0x000007fefeca9000 C:\Windows\system32\CLBCatQ.DLL
0x000007fefbac0000 - 0x000007fefbb0b000 C:\Windows\System32\MMDevApi.dll
0x000007fefbbc0000 - 0x000007fefbcec000 C:\Windows\System32\PROPSYS.dll
0x000007fefab70000 - 0x000007fefabab000 C:\Windows\system32\wdmaud.drv
0x000000006c840000 - 0x000000006c846000 C:\Windows\system32\ksuser.dll
0x000007fefbab0000 - 0x000007fefbab9000 C:\Windows\system32\AVRT.dll
0x000007fefb130000 - 0x000007fefb17f000 C:\Windows\system32\AUDIOSES.DLL
0x000007fefaa40000 - 0x000007fefaa4a000 C:\Windows\system32\msacm32.drv
0x000007fefaa20000 - 0x000007fefaa38000 C:\Windows\system32\MSACM32.dll
0x000007fefaa10000 - 0x000007fefaa19000 C:\Windows\system32\midimap.dll
0x000000006c920000 - 0x000000006c951000 C:\Program Files\WIDCOMM\Bluetooth Software\btkeyind.dll
0x000007fef7210000 - 0x000007fef7218000 C:\Program Files\Hewlett-Packard\HP Quick Launch\HPKBDCTL.dll
0x000000006d550000 - 0x000000006d5f3000 C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCR90.dll
0x000007fef6ca0000 - 0x000007fef6ca8000 C:\Program Files\Hewlett-Packard\HPToneControl\HPKBDCTL.dll
VM Arguments:
java_command: net.minecraft.LauncherFrame
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;c:\Program Files (x86)\Common Files\Ulead Systems\MPEG;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Broadcom\Broadcom 802.11\Driver;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files\Internet Explorer;C:\Program Files (x86)\Windows Live\Shared
USERNAME=user
OS=Windows_NT
PROCESSOR_IDENTIFIER=AMD64 Family 16 Model 5 Stepping 3, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows 7 Build 7601 Service Pack 1
CPU:total 4 (4 cores per cpu, 1 threads per core) family 16 model 5 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnow, 3dnowext, sse4a
Memory: 4k page, physical 6024092k(3229604k free), swap 12046332k(8335372k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (14.3-b01) for windows-amd64 JRE (1.6.0_17-b04), built on Oct 11 2009 00:46:08 by "java_re" with MS VC++ 8.0
time: Tue Oct 23 22:14:43 2012
elapsed time: 17743 seconds
