what's up with the gold plated chokes on the first card? is that just a reflection? o_0?
Lightnings use solid state gold chokes![]()
I mean the off-colour ones
I'm assuming they're just at a slightly different angle though and it's a lighting thing
Oooh, either that or gregster is on his way to setting fire to one![]()
Leaks are a bitch man. I had a faulty bitspower 30 degree rotary that was letting out a slow drip onto my ram.. bad times. It stopped but, once it's leaked.. can't be trusted!
I'm warming to these blocks. I would fashion my own SLI fitting too though. Looks better imo.
God that looks sexy Greg. So much cleaner than mine.
I did prefer your other coolant colour though =)
I liked it but I would have preferred it if it matched the blue of the lights and cables.Absolutely stunning
The red coolant is a big improvement
When do you recon you will do some benching. It will be interesting to see if you can reach the same clocks with less volts on water.
