Could be an issue I need 20GB and have 6GB free. Only have a 60gb SSD for O/S. Think I will need to trim it down a bit..
Several of us had to. Games pretty much did it for me.
I can't see this working now, had really thought ms would have sorted this kind of crap by now.
They have successfully f'ed me right up now.
Ahhhh, so it's your fault for overloading the server![]()
I just submit four more from 4 different email address. So, I probably get total of 8 keys.
Oh... btw it thinks I'm in Wakefield, Leeds... not sure why and how I can change this to Leicestershire!
link ?
If you don't have the patient and don't know what's happening, why did you try installing before info or even release.
If its gone totally **** up, just reinstall windows7 or what ever you have and before you do anything else install w8.
Make sure you have no USB drives in etc, unless your installing from one.
Whats the inetpub file in local disk c ?
I had to remove MSE too. Presumably it has its own version built in or do I need to go and get some protection myself?
None of what you have said makes a lot of sense sorry, but when you have NOTHING to go on but a blank nlack screen and then faced with messages on boot up that it didnt install correctly, exactly how have I done anything wrong?
That sounds like it's iis related
Can it be deleted ?
D'oh
Missed out on all the fun.
The Windows website has been taking off "coming soon"
and the dropbox link with the Windows 8 Upgrade Assistant is showing 404.
My Win7 to Win8 Pro upgrade went almost perfect,it did not find my Canon Pixma iP4500 Printer(USB) ,switched it on and still nothing ,guess its a driver issue or something,worked ok in Win7 x64 so pretty weird issue,trying to solve it now.
