- 22 Mar 2009
Are there many windows updates to download once the upgrade is done?
Mine is only 7 updated that all
I think there was about 7 or 8 for me. And then pretty much every pre-installed app gets an update through Windows Store too.
And one of them is the stupid EU browser choice![]()
Do the pre installed apps just update themselves or do you have to go into something to trigger that to happen?
On the store live tile you'll see a number. That's telling you how many apps need updating. Just go into store and top right corner It'll have a link to updates.
I removed my link to Dropbox since someone posted an official link a few pages back
Yeah it'll create an ISO for you to burn to disc! So a bit pointless paying for the boxed version...
Just to confirm, will Microsoft in the near future announce a stand alone or OEM version ?
You can buy OEM from OcUK. It's not cheap though.
Cheers,
Won't it be a hassle that every time you wanna reinstall windows 8 you'll have to install windows 7 first and then upgrade it to win 8 ?
Reset your PC – Remove all personal data, apps, and settings from the PC, and reinstall Windows.
Refresh your PC – Keep all personal data, Metro style apps, and important settings from the PC, and reinstall Windows.
